Octoprint does not work after disabling octoeverywhere and doing required reboot
log in via ssh, verified that "ps -ef | grep -i octoprint | grep -i python" is running, what it does not, tried to look into logfile, does not give me permissions to do so ->" -bash: /home/pi/.octoprint/logs/octoprint.log: Permission denied"
does not even start to safe mode
unable to download one
OctoPrint version: latest , Anycubic I3 mega, browser: google chrome, operating system: win 10, Plugins: Octolapse, Astroprint, filament sensor reloaded, psu control, touchUI, Simple emergency stop, Mote Lighting control - the system had been running for a goo half year with a rpi 3b
Hey! I'm the developer behind OctoEverywhere! I see in your log that there's a bug in the plugin, causing all of these lines:
2022-02-24 19:28:08,282 - octoprint.plugins.octoeverywhere - INFO - Server con wss://starport-v1.octoeverywhere.com/octoclientws[6] IS past it's RunFor time 20 days, 20:46:31.918454 and IS past it's time since last user activity 20 days, 19:29:00.079240
2022-02-24 19:28:08,283 - octoprint.plugins.octoeverywhere - INFO - Server con wss://starport-v1.octoeverywhere.com/octoclientws[6] RunFor is complete and will be disconnected.
But that shouldn't be affecting your system from booting. To me from your log it looks like the most recent boot in safe mode was successful from the logs perspective. How do you connect to your OctoPrint instance? By IP or using the .local hostname? I do see that the zero config system seems to be unhappy
2022-02-24 19:35:16,819 - zeroconf - WARNING - Error with socket 7 (('192.168.178.106', 5353))): [Errno 101] Network is unreachable
File "/usr/lib/python3.7/asyncio/selector_events.py", line 987, in sendto
I connect to it via ip.... but it only booted into safemode once, after restarting from the plugin disabling, but i instantly rebooted as i saw this.... how do i force it to boot into safemode?
Now i´ve ran ~/oprint/bin/octoprint safemode to boot into safemode, but now it doesnt even show up or wants to connects via ssh..... maybe now reinstall on sd card and then completly fresh setup?
That command (I don't think anyway) doesn't actually boot the server, just sets the flag so that next time it tries to do so. So you would need to restart OctoPrint again following that command.
