I use a fresh install of octoprint, but if I try to use SSH then it says the default password (raspberry) is wrong.
I never used octoprint before so it isn't unlikely that the solution is very obvious.
I flashed Octoprint multible times already. (I also tried to change the default password in the Raspberry pi imager, which didn't help)
no
N/A
Raspberry pi 4B, I used the Octopi image from the raspberry pi imager
I do have a german keyboard, but that's not the problem. (Since I use ssh that can't really be a problem since the keyboard input goes through windows which knows about the german keyboard.)
I understood what you meant. I also tried it now, but that wasn't the problem.
While the input is in english, I use the windows terminal for it and windows only sends the letter, not where on the keyboard I pressed. The kind of keyboard that I use shouldn't make a difference.
Every keyboard by default is English coded.
For different countries they put other key caps on it.
But the output is still English.
So you have to localize your OS when you use another input language than English by using the keyboard mapping..
If you use e.g. Putty to connect to a device via SSH, the keyboard mapping is bypassed, because that certain device has an own OS and in case of OctoPi it is set to English localization.
When you press Y it appears to be a Z at OctoPi.
Via SSH you then can set the localisation of OctoPi to German to fit it to your Keyboard.
