Hi everyone !
My Octoprint on Raspberry pi3B+ doesn't detect the serial port of my Ender 3 anymore. It worked during several month without problem and stopped without any modification from my part.
What i did to identify the problem :
- Check the voltage on the raspberry pi : OK (>5v)
- Change my usb cable to another : Same problem
- Disable all plugins on Octoprint (safe mode) : Same problem
- Reinstall Octopi : Same Problem
- Tested usb port on Raspberry pi (with a usb key) : OK.
To ensure that the raspberry was not powering up the ender 3 I also added a piece of tape on the 5v usb port. I removed it to ensure it was not the problem. This lead me to a strange behavior :
When my printer is not powered ON and my raspberry pi is, I can connect to the serial port (with the tape removed). Then I power ON my printer and the connection stays (however i didn't tested this while printing). If my printer is powered ON before establishing the connection this does not work.
To disable the USB port voltage, I installed a plugin (https://github.com/OutsourcedGuru/OctoPrint-USBControl) but if I disable the 5v on USB after establishing the connection to my printer the connection is lost.
Logs on Octoprint :
Serial port list: []
Changing monitoring state from "Detecting serial port" to "Error: Failed to autodetect serial port, please set it manually."
Logs on raspberry pi (dmesg command) :
3.319890] usb 1-1.2: new full-speed USB device number 4 using dwc_otg
usb 1-1.2: device descriptor read/64, error -32
Printer : Ender 3, Firmware : Marlin 1.1.8
Raspberry pi 3B+ : Octopi 0.17.0, Octoprint 1.4.0
PS: English is not my native language. I hope I made this clear. Thanks for your reply !
