Octoprint doesn't start anymore, last week all worded great. If I go on its IP i see the message: "The octoprint server is currently not running.
I can ping the raspberry ip but if try to access using putty i receive the error "Network error: Software caused connection abort".
I use a raspberry pi 3 B + with octopi, on my PC I have windows.
This is the log file octoprint.log (8 KB)
2019-01-22 13:51:26,962 - octoprint.environment - ERROR - Unexpected error while detecting environment
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/environment.py", line 46, in run_detection
plugin_result = self._detect_from_plugins()
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/environment.py", line 123, in _detect_from_plugins
"environment data from plugin {}".format(implementation._identifier))
AttributeError: 'PiSupportPlugin' object has no attribute '_identifier'
2019-01-22 13:51:26,964 - octoprint.environment - ERROR - Error logging detected environment
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/environment.py", line 136, in log_detected_environment
_log(self._format())
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/environment.py", line 151, in _format
return u"Detected environment is Python {} under {} ({}). Details:\n{}".format(environment["python"]["version"],
KeyError: 'python'
(b) the octoprint log ends with a bunch of junk characters. Is it how you transferred the file?
(c) the ssh error is unrelated. I don't know why you are getting that, but if you can see "the octoprint server is not running" in the web browser, you clearly have a functioning Pi.
Until last week I never switched off octoprint or raspberry, then I decided to switch off so i shut down with the command of the telegram bot (i use a plugin to use it remotely), then my sister turn off the printer plugging off.
I saw the log with notepad++ accessing the ext4 partition of the sd using ext2Fsd and there were the junk characters before I uploaded the file here.
I changed nothing, maybe some sd card corruption?
I have setted many plugins and I don't like do it again if possible... Is there another solution instead of install again octoprint? Could be some router setting (other people manage it)?
If you're good with gparted running on a Linux workstation, you could attempt to repair the second partition on the microSD... but it might be best to start over from scratch and to remember that a good backup is your friend.
