I just install on Raspberry 3 the last version of Octopi. SSH access works but IP access doesn't works.
he problem seems to be known but solution is not clear for me. Thanks for your help.
Edit: I kept the username "pi".
Can you show us the result of ls?
Are you sure installed an OctoPi image?
The OctoPrint folders are missing:
BTW: The OctoPrint folders should be in octopi, not OctoPi . Linux is case sensitive
sudo systemctl start octoprint
