If the run is paused for some reason and during that pause the print head is raised or lowered by command then a resume is done, the head returns to the point in the run where the pause occurred in the X and Y only. It does not know the Z has been changed.
This is something my previous printer prog. did not fail to account for.
Ask if someone could look into a little bit of code so that the resume button can be pressed and be confident the print head will resume the job in all three axis' where it left off.
I don't think the setup has any influence on this problem other than Octoprint version is 1.3.10, OctoPi hasn't been logged into since setup as I've lost my login info.
