Octoprint don't display camera
Are you all doing great ?
I have an issue with the octoprint display camera.
Octoprint don't show any image :
but when I go to my (link http://localhost.:8080/?action=stream) the stream is working.
Do you have any idea of what is causing that ?
(I'm using Ubuntu)
Thank you in advance,
Morgan
Here my url stream working :
and here my webcam settings :
Hello @Morgan !
You may try this setting:
/webcam/?action=stream
@Morgan
your url looks a little bit weird, because behind localhost there is a dot followed by colon.
Try to remove the dot, maybe it helps.
Sometimes it is useful to open the Browser-Dev-Tool (Key: F12) to see some javascript-issues.
Thank you for the answer.
It doesn't work. I still have the same issue.
HI @OllisGit,
I did find the solution with the Browser-dev-tool. It seems to be google chrome that block the acces because it's not secure :
I tried with another web browser and it works perfectly.
Thank you for your help.
