this is the part before, the rest as far as I think isn't relevant. Before I startet the webcamtab update everything worked.
2020-12-21 13:34:18,639 - octoprint.util.comm - INFO - Firmware states that it supports emergency GCODEs to be sent without waiting$
2020-12-21 13:34:26,664 - octoprint.server.preemptive_cache - INFO - ... done in 12.25s
2020-12-21 13:34:49,056 - octoprint.server.util.flask - INFO - Passively logging in user Octoside from ::ffff:192.168.2.22
2020-12-21 13:34:49,058 - octoprint.access.users - INFO - Logged in user: Octoside
2020-12-21 13:34:49,864 - octoprint.server.util.sockjs - INFO - Client connection closed: ::ffff:192.168.2.22
2020-12-21 13:34:51,283 - octoprint.server.util.sockjs - INFO - New connection from client: ::ffff:192.168.2.22
2020-12-21 13:34:51,381 - octoprint.server.util.flask - INFO - Passively logging in user Octoside from ::ffff:192.168.2.22
2020-12-21 13:34:51,382 - octoprint.access.users - INFO - Logged in user: Octoside
2020-12-21 13:34:54,616 - octoprint.server.util.sockjs - INFO - User Octoside logged in on the socket from client ::ffff:192.168.2.$
2020-12-21 13:35:03,809 - octoprint.plugins.softwareupdate - INFO - Starting update of webcamtab to 0.2.0...
2020-12-21 13:35:05,860 - octoprint.plugins.softwareupdate - ERROR - Update of webcamtab can not be performed, please also check pl$
File "/home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/softwareupdate/init.py", line 1788, in _perform_update
target, populated_check, target_version, log_cb=self._log, online=online
File "/home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/softwareupdate/updaters/pip.py", line 144, in perform_update
"Error while executing pip install", (stdout, stderr)
UpdateError: Error while executing pip install
2020-12-21 13:35:19,908 - octoprint.server.util.flask - INFO - Passively logging in user Octoside from ::ffff:192.168.2.22
2020-12-21 13:35:19,912 - octoprint.access.users - INFO - Logged in user: Octoside
2020-12-21 13:35:21,293 - octoprint.server.util.sockjs - INFO - New connection from client: ::ffff:192.168.2.22
2020-12-21 13:35:21,314 - tornado.access - WARNING - 404 GET /favicon.ico (::ffff:192.168.2.22) 10.76ms
2020-12-21 13:35:21,342 - octoprint.server.util.flask - INFO - Passively logging in user Octoside from ::ffff:192.168.2.22
2020-12-21 13:35:21,343 - octoprint.access.users - INFO - Logged in user: Octoside
2020-12-21 13:35:22,463 - octoprint.server.util.sockjs - INFO - Client connection closed: ::ffff:192.168.2.22
2020-12-21 13:36:37,803 - octoprint.plugins.eeprom_marlin - INFO - M503 detected, collecting data
2020-12-21 13:36:37,971 - octoprint.util.comm - ERROR - Error while processing hook ABL_Expert:
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/util/comm.py", line 3874, in _readline
ret = hook(self, ret)
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/util/init.py", line 1890, in wrapper
return f(*args, **kwargs)
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint_ABL_Expert/init.py", line 242, in on_printer_gcode_received
self.printer_cap[cap] = int(line.split(':')[-1])
ValueError: invalid literal for int() with base 10: '; EEPROM can hold 7 meshes. '
2020-12-21 13:36:38,000 - octoprint.plugins.eeprom_marlin - ERROR - Unrecognised EEPROM output line, could not parse
2020-12-21 13:36:38,001 - octoprint.plugins.eeprom_marlin - ERROR - Line: echo: M603 L0.00 U100.00
2020-12-21 13:36:38,005 - octoprint.plugins.eeprom_marlin - INFO - Finished data collection, updating UI
2020-12-21 13:46:19,751 - octoprint.plugin.core - INFO - Loading plugins from /home/pi/oprint/lib/python2.7/site-packages/octoprint$
2020-12-21 13:46:19,935 - octoprint.plugin.core - INFO - Found 34 plugin(s) providing 35 mixin implementations, 77 hook handlers
2020-12-21 13:46:19,942 - octoprint.plugins.pluginmanager - INFO - Plugin webcamtab uninstalled
2020-12-21 13:46:19,947 - octoprint.plugins.pluginmanager - INFO - Cleaning up plugin webcamtab...
2020-12-21 13:46:53,242 - octoprint.plugins.pluginmanager - INFO - Installing single file plugin setup.py from /tmp/tmpAghN1S.py
2020-12-21 13:46:54,130 - octoprint.plugin.core - ERROR - Error loading plugin eeprom_marlin
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/plugin/core.py", line 1298, in _import_plugin
module = _load_module(module_name, spec)
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/plugin/core.py", line 69, in _load_module
return imp.load_module(name, f, filename, details)
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint_eeprom_marlin/init.py", line 17, in
from octoprint_eeprom_marlin import (
ImportError: cannot import name _version
2020-12-21 13:46:54,512 - octoprint.server - INFO - Shutting down...
2020-12-21 13:46:54,663 - octoprint.server - INFO - Calling on_shutdown on plugins
2020-12-21 13:46:54,663 - octoprint.events - INFO - Processing shutdown event, this will be our last event
2020-12-21 13:46:54,670 - octoprint.events - INFO - Event loop shut down
2020-12-21 13:46:55,195 - octoprint.server - INFO - Goodbye!
