Makerbot flavour files x3g work without issue when transfered to (Makerbot) printer.
But when uploaded to Octoprint and "executed" the process throws an error after a few seconds.
Seems Octoprint has an issue with this apparantly binary format.
Updloading gcode and using GPX plugin works (but there the steps/mm setting seems to be ignored) and prints are scaled incorrectly
tried "old" .s3g - same issue
no
Logs
2021-01-26 15:15:41,436 - octoprint.printer.standard.job - INFO - Print job started - origin: local, path: testcube02.x3g, owner: ma, user: ma
2021-01-26 15:15:41,541 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2021-01-26 15:15:41,610 - octoprint.util.comm - INFO - Changing monitoring state from "Starting" to "Printing"
2021-01-26 15:15:43,319 - octoprint.util.comm - ERROR - Something crashed inside the serial connection loop, please report this in OctoPrint's bug tracker:
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/util/comm.py", line 2400, in _monitor
self._handle_ok()
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/util/comm.py", line 3074, in _handle_ok
self._continue_sending()
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/util/comm.py", line 3299, in _continue_sending
elif job_active and self._send_from_job():
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/util/comm.py", line 3944, in _send_from_job
"fileline:{}".format(lineno),
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/util/comm.py", line 4236, in _sendCommand
process(cmd, cmd_type, gcode, subcode, on_sent=on_sent, tags=tags)
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/util/comm.py", line 4195, in process
self._process_atcommand_phase("queuing", cmd, tags=tags)
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/util/comm.py", line 4616, in process_atcommand_phase
handler = getattr(self, "atcommand{}{}".format(atcommand, phase), None)
UnicodeEncodeError: 'ascii' codec can't encode characters in position 13-14: ordinal not in range(128)
2021-01-26 15:15:43,346 - octoprint.util.comm - INFO - Changing monitoring state from "Printing" to "Offline (Error: See octoprint.log for details)"
OctoPrint : 1.5.3
File Check Plugin : 2020.8.7
Firmware Check Plugin : 2020.9.23
GPX Plugin : 2.6.8
