Under Windows (and other OS's) what are the command line arguements for Octoprint.exe?
I'm specifically looking to move the Octoprint "Settings Folder" from %APPDATA%/OctoPrint to D:\OctoPrint_Data.
I've been only able to find under the config.yaml document the following:
If not specified via the command line, the main configuration file config.yaml for OctoPrint is expected in its settings folder, which unless defined differently via the command line is located at ~/.octoprint on Linux, at %APPDATA%/OctoPrint on Windows and at ~/Library/Application Support/OctoPrint on MacOS.
$ octoprint --help
Usage: octoprint [OPTIONS] COMMAND [ARGS]...
Options:
-b, --basedir PATH Specify the basedir to use for configs, uploads,
timelapses etc.
-c, --config PATH Specify the config file to use.
-v, --verbose Increase logging verbosity.
--safe Enable safe mode; disables all third party plugins.
--version Show the version and exit.
--help Show this message and exit.
Commands:
analysis Analysis tools.
client Basic API client.
config Basic config manipulation.
dev Additional commands for development tasks.
plugins Additional commands provided by plugins.
safemode Sets the safe mode flag for the next start.
serve Starts the OctoPrint server.
$ octoprint serve --help
Usage: octoprint serve [OPTIONS]
Options:
timelapses etc.
--host TEXT Specify the host on which to bind the server.
--port INTEGER Specify the port on which to bind the server.
--logging PATH Specify the config file to use for configuring logging.
--iknowwhatimdoing Allow OctoPrint to run as user root.
--debug Enable debug mode.
--ignore-blacklist Disable processing of the plugin blacklist.
