I was printing earlier today without any problem, using a Logitech C270 for timelapse. I unplugged my camera to install a modification, and rebooted my Pi because when I plugged it back in, it wouldn't display. It was like the camera wasn't autodetected. No big deal, I'll just reboot the Pi!
Now, I can't get it to boot into safemode, or regular mode. The logs seem to show the same package throwing errors for every plugin. Not sure if the Tornado devs recently updated it and this is a problem for other people as well, or if I'm just lucky. Anybody have any ideas?
Rebooted, removed the camera, tried to boot to safemode, unplugged and replugged all cables, etc. I even updated OctoPi to the latest via the command line updating steps. I'm not a Python dude, so I don't know too much about the packages, but it seems like a dependency is all messed up now considering that package is missing whenever it tries to load any plugin. dmesg doesn't show any problems either.
Logs (syslog, dmesg, ...)
Snippet:
019-07-16 14:57:04,931 - octoprint.startup - INFO - ******************************************************************************
2019-07-16 14:57:04,933 - octoprint.startup - INFO - Starting OctoPrint 1.3.11
2019-07-16 14:57:04,934 - octoprint.startup - INFO - Starting in SAFE MODE. Third party plugins will be disabled!
2019-07-16 14:57:04,935 - octoprint.startup - INFO - Reason for safe mode: command line flag
2019-07-16 14:57:04,936 - octoprint.startup - INFO - ******************************************************************************
2019-07-16 14:57:04,999 - octoprint.util.connectivity_checker - INFO - Connectivity changed from offline to online
2019-07-16 14:57:05,004 - octoprint.startup - INFO - Blacklist processing done, adding 1 blacklisted plugin versions: roomtemp (any)
2019-07-16 14:57:05,044 - octoprint.plugin.core - INFO - Loading plugins from /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins, /home/pi/.octoprint/plugins and installed plugin packages...
2019-07-16 14:57:05,158 - octoprint.plugin.core - ERROR - Error loading plugin action_command_prompt
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/plugin/core.py", line 863, in _import_plugin
instance = imp.load_module(module_name, f, filename, description)
File "/home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/action_command_prompt/__init__.py", line 9, in <module>
from octoprint.server import user_permission
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/server/__init__.py", line 9, in <module>
from octoprint.vendor.sockjs.tornado import SockJSRouter
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/vendor/sockjs/tornado/__init__.py", line 3, in <module>
from .router import SockJSRouter
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/vendor/sockjs/tornado/router.py", line 11, in <module>
from octoprint.vendor.sockjs.tornado import transports, session, sessioncontainer, static, stats, proto
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/vendor/sockjs/tornado/transports/__init__.py", line 3, in <module>
import octoprint.vendor.sockjs.tornado.transports.pollingbase
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/vendor/sockjs/tornado/transports/pollingbase.py", line 9, in <module>
from octoprint.vendor.sockjs.tornado import basehandler
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/vendor/sockjs/tornado/basehandler.py", line 13, in <module>
from tornado.web import asynchronous, RequestHandler
File "/home/pi/oprint/local/lib/python2.7/site-packages/tornado/web.py", line 93, in <module>
from tornado.routing import (AnyMatches, DefaultHostMatches, HostMatches,
ImportError: cannot import name AnyMatches
2019-07-16 14:57:05,561 - octoprint.plugin.core - ERROR - Error loading plugin appkeys
File "/home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/appkeys/__init__.py", line 16, in <module>
from octoprint.server.util.flask import restricted_access, no_firstrun_access
