Hello,
I recently finished creating my I3-RS. I am very satisfied with it. https://www.makerfr.com/en/imprimante-3d/i3-rs-2018/
Being an automation / home automation fan, I wanted to integrate a RPI (Model B Rev 2) with octoprint into my printer.
All of my prints going through SD / USB drives worked perfectly fine. However, by going through octoprint, it prints well, until at some point (random: Because never the same layer) the printer starts to jerk, then stops dead.
I went to see the octoprint terminal which is the following:
Send: N47700 G1 X117.444 Y105.35 E776.61995*83
Recv: Error:Line Number is not Last Line Number+1, Last Line: 47699
Recv: Resend: 47700
Recv: ok
Recv: Resend: 47700
Recv: ok
Recv: Resend: 47700
Recv: ok
Recv: Resend: 47700
Printer keeps requesting line 47700 again and again, communication stuck
Changing monitoring state from "Printing" to "Error: Printer keeps requesting line 47700 again and again, communication stuck"
Send: M112
Send: N47701 M112*36
Send: N47702 M104 T0 S0*39
Send: N47703 M140 S0*98
Changing monitoring state from "Error: Printer keeps requesting line 47700 again and again, communication stuck" to "Offline (Error: Printer keeps requesting line 47700 again and again, communication stuck)"
It can be seen that the printer is not receiving the 47700 line and create a loopback. (It never hangs on the same line but here I will continue to talk about this line).
I did a little research on the net and found a python plugin that I added in the plugin folder of my RPI.
The plugin is as follows:
# coding=utf-8
from __future__ import absolute_import
def Fix_Bad_Resend(comm, line, *args, **kwargs):
if "Error:Line Number is not Last Line Number+1" not in line:
return line
goodline = line.replace(".*Resend:","Resend:")
return goodline
__plugin_name__ = "Fix Bad Resend"
__plugin_version__ = "1.0.0"
__plugin_description__ = "Fix Bad Resend in printer responses (add newline)"
__plugin_hooks__ = {
"octoprint.comm.protocol.gcode.received": Fix_Bad_Resend
It comes from this topic on the octoprint forum:https://community.octoprint.org/t/problem-error-line-number-is-not-last-line-number-1-last-line-23resend-24/10420/5
I checked that it was in my list of plugins on my dashboard and relaunched a print .... unfortunately, the problem persists.
So I continued my research and found that someone had changed the buffer size in the " Configuration_adv.h " file for the marlin serial link.
#define BLOCK_BUFFER_SIZE 16 // SD,LCD,Buttons take more memory, block buffer needs to be smaller
#else
#define BLOCK_BUFFER_SIZE 16 // maximize block buffer
#endif
// @section serial
// The ASCII buffer for serial input
#define MAX_CMD_SIZE 96
#define BUFSIZE 4
... became ... :
//before 32->16
#define BLOCK_BUFFER_SIZE 32 // SD,LCD,Buttons take more memory, block buffer needs to be smaller
#else
//before 32->16
#define BLOCK_BUFFER_SIZE 32 // maximize block buffer
#endif
// @section serial
//before 32 -> 4
#define BUFSIZE 32
Unfortunately, again without success.
I tried to print the same way but from my PC and Simplify3D and that way it worked.
I wonder if the problem is the baud rate to my printer of the gcode in octoprint?
Can we change this setting somewhere?
So I come here to find out if anyone has the solution to my problem or a lead that allowed me to move forward.
thank you in advance![]()
octoprint.log (420.7 KB) serial.log (296 Bytes)
OctoPrint 1.4.2
Python 2.7.16
OctoPi 0.17.0
Printer:
MakerFr I3-RS
Modified version of Marlin 1.1.8
Motherboard: MKS Base 1.5
Screen: TFT MKS 3.2"
RPI model B rev2 (2 USB ports)
