Apologies on any poor descriptions, I am really new to 3D printing.
One thing that I would like to note is that OctoPrint seemed to be doing perfectly fine since I got my printer a few months ago. It seems like this started happening since the last OctoPrint update, not sure if that is coincidental but that is something that I would like to note right off the bat.
OctoPrint seems to be causing random initial layer height and other printing artifacts. See the image below in the next section to see, the print on the left is the one from OctoPrint, both the initial layer and the support structures seem to be printed significantly worse, the actual object seems fine.
Tried looking at the gcode to see if I could find any anomalies between gcode that seemed to print fine and that which didn't (nothing jumped out at me), I tried different slicer settings and manually re-leveling bed (this caused my hot end to push into my print bed and drag around the surface
). The reason I tried re-leveling the bed was because it seemed that the initial starting height was almost doubled. The thing that is really confusing me is that it seems almost random when I get the poor results from OctoPrint.
Finally I took gcode that was consistently printing poorly from OctoPrint and loaded the gcode to the SD card and printed directly from that (with my raspberry pi disconnected from the printer) and it printed perfectly (relative to my results from OctoPrint). So I am at the point where I think it has something to do with OctoPrint, but I am not certain.
In the image below is the EXACT same gcode for both prints, the print on the left was from OctoPrint the one on the right was from the SD card.
I want to emphasize, depending on the gcode, OctoPrint sometimes gives me comparable results to printing from the SD card. The above image does not represent all my prints from OctoPrint.
Yes, at first this seemed to work, but then eventually (randomly) the started printing strangely again (with the same gcode).
No.
octoprint-systeminfo-20210629040053.zip (19.9 KB)
OctoPrint version -1.6.1
OctoPi version - Version 0.18.0, running on Raspberry Pi 4 Model B Rev 1.1 (Wifi connection)
Printer - Ender 3 Max (no automatic bed leveler), Stock minus Raspberry Pi
Board - V 4.2.2
Firmware (I was have not changed this since I got the printer) - 1.0.1.8
Browser (that I am using to interface with OctoPrint) - Brave
Operating System (that I am using to interface with OctoPrint) - Win 10 21H1 (19043.1052)
