What's the problem?
Connecting a 1024x600 touchscreen via HDMI (for OctoDash) appears to freeze OctoPrint and makes it inaccessible. Unplugging the touchscreen will allow OctoPrint to recover, but it takes a minute or two before I can refresh the webpage and it works again. The touchscreen (with OctoDash) works even if OctoPrint is frozen, though OctoDash will display an error when it tries to talk to OctoPrint. Issue is intermittent, since everything worked for the past couple months but stopped today (no changes besides booting up Pi)
Debugging steps:
Disconnected touch (via USB) - didn't work
Isolated the power supplies so monitor was separately powered - didn't work
Checked that I could ping OctoPi while Octoprint was frozen - ping failed
Modified the config.txt file - temporarily worked
- enabled hdmi_force_hotplug=1
- enabled hdmi_group=2
- enabled hdmi_mode=23
- enabled hdmi_drive=1
I tried other config.txt settings, including setting the following, but it didn't work either:
hdmi_cvt=1024 600 60 6 0 0 0
With the above config.txt settings changed everything worked for for the past couple months. Turned on the Pi today, and it's back to where it was before: if screen plugged in --> no Octoprint
Additional information about my setup
OctoPrint v1.5.2 (latest)
OctoDash v2.1.2 (latest)
Raspberry Pi 3B+
Screen: TeNizo 7 inch Touchscreen Monitor (Amazon)
Printer: MakerGear M2 (not connected for these tests)
Logging
octoprint.log (735.2 KB)
syslog.log (717.1 KB)
haproxy.log (4.4 KB)
