serial.log
2019-01-17 22:23:00,091 - serial.log is currently not enabled, you can enable it via Settings > Serial Connection > Log communication to serial.log
2019-01-17 22:28:54,979 - Enabling serial logging
2019-01-17 22:28:55,796 - Recv: T:16.43 /0.00 B:17.00 /0.00 T0:16.43 /0.00 T1:17.14 /0.00 @:0 B@:0 @0:0 @1:0
2019-01-17 22:28:57,553 - Recv: T:16.52 /0.00 B:17.00 /0.00 T0:16.52 /0.00 T1:17.10 /0.00 @:0 B@:0 @0:0 @1:0
2019-01-17 22:28:59,552 - Recv: T:16.43 /0.00 B:17.03 /0.00 T0:16.43 /0.00 T1:17.10 /0.00 @:0 B@:0 @0:0 @1:0
2019-01-17 22:29:01,506 - Send: G91
2019-01-17 22:29:01,516 - Recv: ok P15 B9
2019-01-17 22:29:01,527 - Send: G1 Y100 F6000
2019-01-17 22:29:01,537 - Send: G90
2019-01-17 22:29:01,539 - Recv: ok P13 B9
2019-01-17 22:29:01,549 - Recv: ok P13 B9
2019-01-17 22:29:01,558 - Recv: T:16.47 /0.00 B:17.03 /0.00 T0:16.47 /0.00 T1:17.10 /0.00 @:0 B@:0 @0:0 @1:0
2019-01-17 22:29:03,520 - Send: G91
2019-01-17 22:29:03,543 - Send: G1 X100 F6000
2019-01-17 22:29:03,545 - Recv: ok P15 B9
2019-01-17 22:29:03,550 - Send: G90
2019-01-17 22:29:03,556 - Recv: T:16.43 /0.00 B:17.03 /0.00 T0:16.43 /0.00 T1:17.10 /0.00 @:0 B@:0 @0:0 @1:0
2019-01-17 22:29:03,562 - Recv: ok P13 B9
2019-01-17 22:29:03,564 - Recv: ok P13 B9
2019-01-17 22:29:05,554 - Recv: T:16.43 /0.00 B:17.10 /0.00 T0:16.43 /0.00 T1:17.05 /0.00 @:0 B@:0 @0:0 @1:0
2019-01-17 22:29:07,568 - Recv: T:16.47 /0.00 B:17.03 /0.00 T0:16.47 /0.00 T1:17.14 /0.00 @:0 B@:0 @0:0 @1:0
2019-01-17 22:29:08,299 - Send: G91
2019-01-17 22:29:08,319 - Recv: ok P15 B9
2019-01-17 22:29:08,329 - Send: G1 Z10 F200
2019-01-17 22:29:08,335 - Send: G90
2019-01-17 22:29:08,341 - Recv: ok P13 B9
2019-01-17 22:29:08,344 - Recv: ok P13 B9
2019-01-17 22:29:09,568 - Recv: T:16.47 /0.00 B:17.10 /0.00 T0:16.47 /0.00 T1:17.01 /0.00 @:0 B@:0 @0:0 @1:0
2019-01-17 22:29:11,566 - Recv: T:16.43 /0.00 B:17.10 /0.00 T0:16.43 /0.00 T1:16.92 /0.00 @:0 B@:0 @0:0 @1:0
2019-01-17 22:29:12,520 - Send: G91
2019-01-17 22:29:12,542 - Recv: ok P15 B9
2019-01-17 22:29:12,547 - Send: G28 Z0
2019-01-17 22:29:12,554 - Send: G90
2019-01-17 22:29:12,560 - Recv: echo:Active Extruder: 0
2019-01-17 22:29:12,565 - Recv: echo:Home XY first
2019-01-17 22:29:12,569 - Recv: echo:Active Extruder: 0
2019-01-17 22:29:12,571 - Recv: X:110.00 Y:110.00 Z:10.00 E:0.00 Count X:11055 Y:11055 Z:16000
2019-01-17 22:29:12,573 - Recv: ok P15 B9
2019-01-17 22:29:12,576 - Recv: ok P15 B9
2019-01-17 22:29:13,565 - Recv: T:16.47 /0.00 B:17.07 /0.00 T0:16.47 /0.00 T1:17.10 /0.00 @:0 B@:0 @0:0 @1:0
2019-01-17 22:29:15,568 - Recv: T:16.52 /0.00 B:17.03 /0.00 T0:16.52 /0.00 T1:17.14 /0.00 @:0 B@:0 @0:0 @1:0
2019-01-17 22:29:16,993 - Send: G91
2019-01-17 22:29:17,001 - Recv: ok P15 B9
2019-01-17 22:29:17,022 - Send: G28 Z0
2019-01-17 22:29:17,028 - Send: G90
2019-01-17 22:29:17,033 - Recv: echo:Active Extruder: 0
2019-01-17 22:29:17,035 - Recv: echo:Home XY first
2019-01-17 22:29:17,037 - Recv: echo:Active Extruder: 0
2019-01-17 22:29:17,040 - Recv: X:110.00 Y:110.00 Z:10.00 E:0.00 Count X:11055 Y:11055 Z:16000
2019-01-17 22:29:17,047 - Recv: ok P15 B9
2019-01-17 22:29:17,052 - Recv: ok P15 B9
2019-01-17 22:29:17,567 - Recv: T:16.47 /0.00 B:17.00 /0.00 T0:16.47 /0.00 T1:17.05 /0.00 @:0 B@:0 @0:0 @1:0
2019-01-17 22:29:19,567 - Recv: T:16.43 /0.00 B:17.07 /0.00 T0:16.43 /0.00 T1:17.05 /0.00 @:0 B@:0 @0:0 @1:0
2019-01-17 22:29:19,615 - Send: G91
2019-01-17 22:29:19,624 - Send: G28 X0 Y0
2019-01-17 22:29:19,630 - Send: G90
2019-01-17 22:29:19,631 - Recv: ok P15 B9
2019-01-17 22:29:19,634 - Recv: echo:Active Extruder: 0
2019-01-17 22:29:21,569 - Recv: T:16.52 /0.00 B:17.03 /0.00 T0:16.52 /0.00 T1:17.01 /0.00 @:0 B@:0 @0:0 @1:0
2019-01-17 22:29:22,806 - Recv: echo:Active Extruder: 0
2019-01-17 22:29:22,811 - Recv: X:-2.00 Y:0.00 Z:10.00 E:0.00 Count X:-201 Y:0 Z:16000
2019-01-17 22:29:22,815 - Recv: ok P15 B8
2019-01-17 22:29:22,824 - Recv: ok P15 B9
2019-01-17 22:29:23,568 - Recv: T:16.47 /0.00 B:17.00 /0.00 T0:16.47 /0.00 T1:17.01 /0.00 @:0 B@:0 @0:0 @1:0
2019-01-17 22:29:25,567 - Recv: T:16.47 /0.00 B:17.14 /0.00 T0:16.47 /0.00 T1:17.05 /0.00 @:0 B@:0 @0:0 @1:0
2019-01-17 22:29:27,525 - Send: G91
2019-01-17 22:29:27,542 - Send: G28 Z0
2019-01-17 22:29:27,546 - Recv: ok P15 B9
2019-01-17 22:29:27,550 - Send: G90
2019-01-17 22:29:27,554 - Recv: echo:Active Extruder: 0
2019-01-17 22:29:27,565 - Recv: T:16.43 /0.00 B:17.07 /0.00 T0:16.43 /0.00 T1:17.14 /0.00 @:0 B@:0 @0:0 @1:0
2019-01-17 22:29:29,569 - Recv: T:16.43 /0.00 B:17.03 /0.00 T0:16.43 /0.00 T1:17.14 /0.00 @:0 B@:0 @0:0 @1:0
2019-01-17 22:29:31,568 - Recv: T:16.43 /0.00 B:17.07 /0.00 T0:16.43 /0.00 T1:17.10 /0.00 @:0 B@:0 @0:0 @1:0
2019-01-17 22:29:33,567 - Recv: T:16.43 /0.00 B:17.00 /0.00 T0:16.43 /0.00 T1:17.05 /0.00 @:0 B@:0 @0:0 @1:0
2019-01-17 22:29:34,593 - Recv: echo:Active Extruder: 0
2019-01-17 22:29:34,594 - Recv: X:10.00 Y:10.00 Z:0.00 E:0.00 Count X:1005 Y:1005 Z:0
2019-01-17 22:29:34,605 - Recv: ok P15 B8
2019-01-17 22:29:34,611 - Recv: ok P15 B9
2019-01-17 22:29:35,566 - Recv: T:16.52 /0.00 B:17.03 /0.00 T0:16.52 /0.00 T1:17.10 /0.00 @:0 B@:0 @0:0 @1:0
2019-01-17 22:29:35,632 - Send: G91
2019-01-17 22:29:35,636 - Recv: ok P15 B9
2019-01-17 22:29:35,645 - Send: G1 Y100 F6000
2019-01-17 22:29:35,655 - Recv: ok P13 B9
2019-01-17 22:29:35,660 - Send: G90
2019-01-17 22:29:35,670 - Recv: ok P13 B9
2019-01-17 22:29:36,532 - Send: G91
2019-01-17 22:29:36,542 - Recv: ok P14 B9
2019-01-17 22:29:36,554 - Send: G1 X100 F6000
2019-01-17 22:29:36,558 - Send: G90
2019-01-17 22:29:36,565 - Recv: ok P13 B9
2019-01-17 22:29:36,567 - Recv: ok P13 B9
2019-01-17 22:29:37,568 - Recv: T:16.47 /0.00 B:17.03 /0.00 T0:16.47 /0.00 T1:17.14 /0.00 @:0 B@:0 @0:0 @1:0
2019-01-17 22:29:39,568 - Recv: T:16.47 /0.00 B:17.03 /0.00 T0:16.47 /0.00 T1:17.14 /0.00 @:0 B@:0 @0:0 @1:0
2019-01-17 22:29:40,903 - Send: G91
2019-01-17 22:29:40,910 - Recv: ok P15 B9
2019-01-17 22:29:40,928 - Send: G28 Z0
2019-01-17 22:29:40,935 - Send: G90
2019-01-17 22:29:40,941 - Recv: echo:Active Extruder: 0
2019-01-17 22:29:41,570 - Recv: T:16.52 /0.00 B:17.03 /0.00 T0:16.52 /0.00 T1:17.10 /0.00 @:0 B@:0 @0:0 @1:0
2019-01-17 22:29:43,570 - Recv: T:16.43 /0.00 B:17.07 /0.00 T0:16.43 /0.00 T1:17.14 /0.00 @:0 B@:0 @0:0 @1:0
2019-01-17 22:29:45,568 - Recv: T:16.52 /0.00 B:17.03 /0.00 T0:16.52 /0.00 T1:17.14 /0.00 @:0 B@:0 @0:0 @1:0
2019-01-17 22:29:45,880 - Recv: echo:Active Extruder: 0
2019-01-17 22:29:45,884 - Recv: X:10.00 Y:10.00 Z:0.00 E:0.00 Count X:1005 Y:1005 Z:0
2019-01-17 22:29:45,886 - Recv: ok P15 B8
2019-01-17 22:29:45,888 - Recv: ok P15 B9
2019-01-17 22:29:47,576 - Recv: T:16.47 /0.00 B:17.10 /0.00 T0:16.47 /0.00 T1:17.10 /0.00 @:0 B@:0 @0:0 @1:0
2019-01-17 22:29:49,574 - Recv: T:16.47 /0.00 B:17.03 /0.00 T0:16.47 /0.00 T1:17.10 /0.00 @:0 B@:0 @0:0 @1:0
2019-01-17 22:29:51,578 - Recv: T:16.43 /0.00 B:17.14 /0.00 T0:16.43 /0.00 T1:17.14 /0.00 @:0 B@:0 @0:0 @1:0
2019-01-17 22:29:53,576 - Recv: T:16.47 /0.00 B:17.17 /0.00 T0:16.47 /0.00 T1:17.14 /0.00 @:0 B@:0 @0:0 @1:0
2019-01-17 22:29:55,575 - Recv: T:16.43 /0.00 B:17.14 /0.00 T0:16.43 /0.00 T1:17.10 /0.00 @:0 B@:0 @0:0 @1:0
2019-01-17 22:29:57,578 - Recv: T:16.43 /0.00 B:17.03 /0.00 T0:16.43 /0.00 T1:17.05 /0.00 @:0 B@:0 @0:0 @1:0
2019-01-17 22:29:59,577 - Recv: T:16.43 /0.00 B:17.03 /0.00 T0:16.43 /0.00 T1:17.14 /0.00 @:0 B@:0 @0:0 @1:0
2019-01-17 22:30:01,575 - Recv: T:16.43 /0.00 B:17.07 /0.00 T0:16.43 /0.00 T1:17.10 /0.00 @:0 B@:0 @0:0 @1:0
2019-01-17 22:30:03,575 - Recv: T:16.43 /0.00 B:17.14 /0.00 T0:16.43 /0.00 T1:17.14 /0.00 @:0 B@:0 @0:0 @1:0
2019-01-17 22:30:05,577 - Recv: T:16.52 /0.00 B:17.00 /0.00 T0:16.52 /0.00 T1:17.10 /0.00 @:0 B@:0 @0:0 @1:0
2019-01-17 22:30:07,577 - Recv: T:16.43 /0.00 B:17.14 /0.00 T0:16.43 /0.00 T1:17.05 /0.00 @:0 B@:0 @0:0 @1:0
2019-01-17 22:30:09,575 - Recv: T:16.43 /0.00 B:17.07 /0.00 T0:16.43 /0.00 T1:17.10 /0.00 @:0 B@:0 @0:0 @1:0
2019-01-17 22:30:11,575 - Recv: T:16.52 /0.00 B:17.10 /0.00 T0:16.52 /0.00 T1:17.10 /0.00 @:0 B@:0 @0:0 @1:0
2019-01-17 22:30:13,578 - Recv: T:16.52 /0.00 B:17.14 /0.00 T0:16.52 /0.00 T1:17.10 /0.00 @:0 B@:0 @0:0 @1:0
2019-01-17 22:30:15,577 - Recv: T:16.43 /0.00 B:17.03 /0.00 T0:16.43 /0.00 T1:17.10 /0.00 @:0 B@:0 @0:0 @1:0
