I have a RPI2b that has been running octoprint flawlessly for a couple of years (I'm just a hobbiest so only use it sporadically throughout each year). I noticed the last couple of time I switched it on it would fail to boot past the rainbow screen, powering off and on once or twice would usually solve this issue until today when it persists to stay on the rainbow screen. Can someone point me towards the first steps of resolving this problem?
I have the official RPI usb adaptor and I've also tried another official adaptor to rule out problem power issues
Made a new RPI OS image on a different card and successfully booted to the setup screen
Put the SD card into a linux system to check both the boot and octoprint partitions are visible
N/A
more than likely corrupted/failed SD card. flash octopi fresh and put it in and see if it comes on. if it does then you might be able to use that linux system and retrieve your settings from /home/pi/.octoprint.
