2019-01-30 06:33:55,091 - octoprint.startup - INFO - ******************************************************************************
2019-01-30 06:33:55,094 - octoprint.startup - INFO - Starting OctoPrint 1.3.10
2019-01-30 06:33:55,096 - octoprint.startup - INFO - ******************************************************************************
2019-01-30 06:33:55,847 - octoprint.plugin.core - INFO - Loading plugins from /home/octoprint/OctoPrint-1.3.10/src/octoprint/plugins, /home/octoprint/.octoprint/plugins and installed plugin packages...
2019-01-30 06:33:57,057 - octoprint.plugin.core - INFO - Plugin Pi Support Plugin did not pass check, not loading.
2019-01-30 06:33:57,691 - octoprint.plugins.discovery - INFO - pybonjour is not installed, Zeroconf Discovery won't be available
2019-01-30 06:33:57,709 - octoprint.plugin.core - INFO - Found 14 plugin(s) providing 14 mixin implementations, 17 hook handlers
2019-01-30 06:33:57,830 - octoprint.server.heartbeat - INFO - Starting server heartbeat, 900.0s interval
2019-01-30 06:33:57,863 - octoprint.server - INFO - Intermediary server started
2019-01-30 06:33:57,864 - octoprint.plugin.core - INFO - Loading plugins from /home/octoprint/OctoPrint-1.3.10/src/octoprint/plugins, /home/octoprint/.octoprint/plugins and installed plugin packages...
2019-01-30 06:33:57,892 - octoprint.plugin.core - INFO - Plugin Pi Support Plugin did not pass check, not loading.
2019-01-30 06:33:58,048 - octoprint.plugin.core - INFO - Found 14 plugin(s) providing 14 mixin implementations, 17 hook handlers
2019-01-30 06:33:58,093 - octoprint.filemanager.storage - INFO - Initializing the file metadata for /home/octoprint/.octoprint/uploads...
2019-01-30 06:33:58,096 - octoprint.filemanager.storage - INFO - ... file metadata for /home/octoprint/.octoprint/uploads initialized successfully.
2019-01-30 06:33:58,139 - octoprint.plugins.softwareupdate - INFO - Loaded version cache from disk
2019-01-30 06:34:03,268 - octoprint.util.pip - INFO - Using "/usr/bin/python2 -m pip" as command to invoke pip
2019-01-30 06:34:08,387 - octoprint.util.pip - INFO - Version of pip is 9.0.1
2019-01-30 06:34:08,440 - octoprint.util.pip - INFO - pip installs to /usr/lib/python2.7/dist-packages (writable -> no), --user flag needed -> yes, virtual env -> no
2019-01-30 06:34:08,441 - octoprint.util.pip - INFO - ==> pip ok -> yes
2019-01-30 06:34:08,448 - octoprint.plugin.core - INFO - Initialized 14 plugin implementation(s)
2019-01-30 06:34:08,459 - octoprint.plugin.core - INFO - 14 plugin(s) registered with the system:
|  Action Command Prompt Support (bundled) = /home/octoprint/OctoPrint-1.3.10/src/octoprint/plugins/action_command_prompt
|  Announcement Plugin (bundled) = /home/octoprint/OctoPrint-1.3.10/src/octoprint/plugins/announcements
|  Anonymous Usage Tracking (bundled) = /home/octoprint/OctoPrint-1.3.10/src/octoprint/plugins/tracking
|  Application Keys Plugin (bundled) = /home/octoprint/OctoPrint-1.3.10/src/octoprint/plugins/appkeys
|  Backup & Restore (bundled) = /home/octoprint/OctoPrint-1.3.10/src/octoprint/plugins/backup
|  Core Wizard (bundled) = /home/octoprint/OctoPrint-1.3.10/src/octoprint/plugins/corewizard
|  CuraEngine (<= 15.04) (bundled) = /home/octoprint/OctoPrint-1.3.10/src/octoprint/plugins/cura
|  Discovery (bundled) = /home/octoprint/OctoPrint-1.3.10/src/octoprint/plugins/discovery
|  Force Login (bundled) = /home/octoprint/OctoPrint-1.3.10/src/octoprint/plugins/forcelogin
|  Logging (bundled) = /home/octoprint/OctoPrint-1.3.10/src/octoprint/plugins/logging
|  Plugin Manager (bundled) = /home/octoprint/OctoPrint-1.3.10/src/octoprint/plugins/pluginmanager
|  Printer Safety Check (bundled) = /home/octoprint/OctoPrint-1.3.10/src/octoprint/plugins/printer_safety_check
|  Software Update (bundled) = /home/octoprint/OctoPrint-1.3.10/src/octoprint/plugins/softwareupdate
|  Virtual Printer (bundled) = /home/octoprint/OctoPrint-1.3.10/src/octoprint/plugins/virtual_printer
2019-01-30 06:34:08,479 - octoprint.environment - INFO - Detected environment is Python 2.7.15rc1 under Linux (linux2). Details:
|  hardware:
|    cores: 4
|    freq: 1200.0
|    ram: 483958784
|  os:
|    platform: linux2
|  python:
|    pip: 9.0.1
|    version: 2.7.15rc1
2019-01-30 06:34:08,490 - octoprint.server - INFO - Reset webasset folder /home/octoprint/.octoprint/generated/webassets...
2019-01-30 06:34:08,492 - octoprint.server - INFO - Reset webasset folder /home/octoprint/.octoprint/generated/.webassets-cache...
2019-01-30 06:34:08,977 - octoprint.server - INFO - Shutting down intermediary server...
2019-01-30 06:34:09,409 - octoprint.server - INFO - Intermediary server shut down
2019-01-30 06:34:09,413 - octoprint.events - INFO - Processing startup event, this is our first event
2019-01-30 06:34:09,414 - octoprint.events - INFO - Adding 0 events to queue that were held back before startup event
2019-01-30 06:34:09,417 - octoprint.filemanager - INFO - Adding backlog items from all storage types to analysis queue...
2019-01-30 06:34:09,426 - octoprint.filemanager - INFO - Added 0 items from storage type "local" to analysis queue
2019-01-30 06:34:09,434 - octoprint.plugins.cura - INFO - Path to CuraEngine has not been configured or does not exist (currently set to None), Cura will not be selectable for slicing
2019-01-30 06:34:09,445 - octoprint.plugins.discovery - INFO - Registered OctoPrint instance on orangepilite for SSDP
2019-01-30 06:34:09,453 - octoprint.server - INFO - Listening on http://[::]:5000
2019-01-30 06:34:09,495 - octoprint.plugins.pluginmanager - INFO - Loaded plugin repository data from disk, was still valid
2019-01-30 06:34:10,045 - octoprint.plugins.pluginmanager - INFO - Loaded notice data from disk, was still valid
2019-01-30 06:34:14,699 - octoprint.util.pip - INFO - Using "/usr/bin/python2 -m pip" as command to invoke pip
2019-01-30 06:34:14,702 - octoprint.util.pip - INFO - pip installs to /usr/lib/python2.7/dist-packages (writable -> no), --user flag needed -> yes, virtual env -> no
2019-01-30 06:34:14,702 - octoprint.util.pip - INFO - ==> pip ok -> yes
2019-01-30 06:34:14,764 - octoprint.server.preemptive_cache - INFO - Preemptively caching / (ui _default) for {'query_string': 'l10n=en', 'path': '/', 'base_url': 'http://192.168.200.143:5000/'}
2019-01-30 06:34:15,871 - octoprint.server.preemptive_cache - INFO - ... done in 1.11s
2019-01-30 06:48:57,834 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2019-01-30 07:03:57,838 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2019-01-30 07:18:57,840 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2019-01-30 07:33:57,842 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2019-01-30 07:48:57,845 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2019-01-30 08:03:57,848 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2019-01-30 08:18:57,851 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2019-01-30 08:25:00,344 - tornado.access - WARNING - 404 GET /favicon.ico (192.168.200.141) 8.89ms
2019-01-30 08:33:57,855 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2019-01-30 08:36:39,220 - octoprint.server - INFO - Shutting down...
2019-01-30 08:36:39,312 - octoprint.events - INFO - Processing shutdown event, this will be our last event
2019-01-30 08:36:39,314 - octoprint.events - INFO - Event loop shut down
2019-01-30 08:36:39,339 - octoprint.server - INFO - Goodbye!
