After installing octoprint on my raspi 3 it works fine for couple of hours, but eventually wifi will disconnect and device seems to go to sleep as connecting keyboard and monitor does not wake it up. I just get a black screen.
I found it could be related to power management issue so i made sure that option is turned off.
I have installed latest version of raspbian from raspberry pi website just to test if it will drop connection, it does not so i assume theres an issue somewhere in octopi's configuration.
Im using latest octoprint from download section, after setup i update octoprint to 1.3.6 as it asks for it.
Using onboard wifi, i do have wifi dongle but thats another can of worms to be sorted later.
I'm having the same issue. I tried your fix, but when I open the config file, it is blank. I'm on
OctoPrint version : 1.3.11
OctoPi version : 0.16.0
Do you know what could be going on?
I'll try that if my current solution doesn't work. I read in a comment somewhere to add the ‘iwconfig wlan0 power off’ command to the /etc/rc.local script. I'm testing this solution now.
