Ive followed the tutorial here thingiverse.com/thing:3372599
Once i finish i type sudo reboot and once it reboots im met with the The OctoPrint server is currently not running page.
Looking at the log i found this error
2019-12-27 07:52:37,654 - octoprint.printer.profile - ERROR - Profile _default does not exist, creating _default again and setting it as default
I dont know where to go from here
2019-12-27 07:52:32,953 - octoprint.startup - INFO - Starting OctoPrint 1.3.12
2019-12-27 07:52:32,954 - octoprint.startup - INFO - ******************************************************************************
2019-12-27 07:52:33,143 - octoprint.plugin.core - INFO - Loading plugins from /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins, /home/p$
2019-12-27 07:52:36,803 - octoprint.plugin.core - INFO - Found 15 plugin(s) providing 15 mixin implementations, 23 hook handlers
2019-12-27 07:52:37,146 - octoprint.server.heartbeat - INFO - Starting server heartbeat, 900.0s interval
2019-12-27 07:52:37,314 - octoprint.server - INFO - Intermediary server started
2019-12-27 07:52:37,316 - octoprint.plugin.core - INFO - Loading plugins from /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins, /home/p$
2019-12-27 07:52:37,648 - octoprint.plugin.core - INFO - Found 15 plugin(s) providing 15 mixin implementations, 23 hook handlers
2019-12-27 07:52:37,981 - octoprint.filemanager.storage - INFO - Initializing the file metadata for /home/pi/.octoprint/uploads...
2019-12-27 07:52:37,986 - octoprint.filemanager.storage - INFO - ... file metadata for /home/pi/.octoprint/uploads initialized successfully.
2019-12-27 07:52:40,682 - octoprint.util.pip - INFO - Using "/home/pi/oprint/bin/python2 -m pip" as command to invoke pip
2019-12-27 07:52:42,940 - octoprint.util.pip - INFO - Version of pip is 19.3.1
2019-12-27 07:52:42,944 - octoprint.util.pip - INFO - pip installs to /home/pi/oprint/lib/python2.7/site-packages (writable -> yes), --user flag nee$
2019-12-27 07:52:42,946 - octoprint.util.pip - INFO - ==> pip ok -> yes
2019-12-27 07:52:42,958 - octoprint.plugin.core - INFO - Initialized 15 plugin implementation(s)
2019-12-27 07:52:43,202 - octoprint.plugin.core - INFO - 15 plugin(s) registered with the system:
Octoprint 1.3.12
Octopi 0.17.0
