Octoprint keeps increasing print speed with each layer. It is like octoprint is ignoring the print speed set in cura and just increasing the speed with each layer. it seems like it stops acellerating once it reaches the limits of the bus speed resulting in crapy prints. I can manually reduce the speed in the controle section, but even if i do 50% feed rate it will creep back up. if i repress the feed rate button ti will instantly return to the slower feed rate.
I have tried updating to octo and cura to the newest versions but the problem remaines.
I'm am not getting any obvious error messages.
octo is running on a pi3b+, the anet A8 is updated to skynet firmware.
