I tried to upgrade my OctoPi to Python 3 using the script I found here: GitHub - cp2004/Octoprint-Upgrade-To-Py3: A script to move an existing OctoPrint install from Python 2 to Python 3
Unfortunately, my Keyboard is connected to 2 computers with an USB switch and I sent Ctrl+C to the wrong machine - and cancelled the process while running...
The installation of Python 3 has been finished (And therefore the script refuses to run again) but the installation of Octoprint did not complete.
I attached a screenshot below showing the latest output of the script.
A Webserver seems to be running, as I get the " The OctoPrint server is currently not running" Page when opening Octoprint in my Browser, but thats all.
So now I somehow have to repeat the installation part of the script, if possible without loosing my Plugins and their configuration.
But I have no idea how to do so...
Is there any way to repair my installation?
Start/Restart the service with sudo service octoprint (re)start - Command provides no output and does nothing
ps -ef | grep -i octoprint | grep -i python says grep: octoprint: No such file or directory
Did not find out how to do so from the command line
I guess not
You can download this in OctoPrint's System Information dialog ... no bundle, no support!) -> Obviously I can't use the System information dialog!
See screenshot:
If it helps I can add the octoprint.log, but as the latest entry is the goodbye from the server right before starting the upgrade, I don't thnik it will be useful.
