Octoprint Installed Natively on Printer mainboard....Cannot connect to printer
I installed Octoprint on my printer directly on the mainboard. It is an Artillery Sidewinder X4 Pro and is running a custom MKS PI, I upgraded the emmc to 32GBs and installed Octoprint. No issue there. I had Klipper installed and I used KIAUH to install Octoprint.
The issue is that I cannot connect to the printer at all, it gets stuck at Opening Serial Connection
I have ran dmesg | grep tty
[ 0.002652] printk: console [tty0] enabled
[ 1.579783] ff110000.serial: ttyS0 at MMIO 0xff110000 (irq = 19, base_baud = 1500000) is a 16550A
[ 1.581999] ff120000.serial: ttyS1 at MMIO 0xff120000 (irq = 20, base_baud = 1500000) is a 16550A
[ 1.584039] ff130000.serial: ttyS2 at MMIO 0xff130000 (irq = 21, base_baud = 1500000) is a 16550A
[ 1.678921] printk: console [ttyS2] enabled
[ 8.118362] cdc_acm 1-1:1.0: ttyACM0: USB ACM device
[ 29.252926] cdc_acm 1-1:1.0: ttyACM0: USB ACM device
[ 48.335217] cdc_acm 1-1:1.0: ttyACM0: USB ACM device
I added tty0 to the ports and i added 1500000 to the baud rates in octoprint and still nothing, I get stuck on Opening serial connection anywhere besides Auto Auto which doesn't work at all
I installed and used setserial to make sure the serial ports were setup properly
Yes, that made no difference
octoprint-systeminfo-20240716083002.zip (21.8 KB)
Attached above
MKS PI Mainboard, armbian buster installed. Let me know what else you might need?
Did you use the octoprint_deploy script or manually install following the linux instructions? Almost sounds like the user configured running the service might not be a member of the correct groups for applying permissions. That being said, most embedded OS printers are running Klipper instead of Marlin, which requires a different setup for OctoPrint to communicate to Klipper, see here: https://www.klipper3d.org/Installation.html#configuring-octoprint-to-use-klipper
Argh, let me add that information to the post.
I'm running Klipper and used kiauh to install octoprint, I believe it uses octo deploy.
I can try modding the permissions to see if that works
ah, I'm not as familiar with KIAUH, but I think the setup for OctoPrint would be the same as linked before, setting up a custom serial port.
That f***ing did it
Thank you. I was looking all over for that info and figured I was using the wrong search terms.
Thank you so much
