Octoprint disconnects every evening, and requires a SSH reboot or a manual power cycle to reconnect. It had previously no issues for over a year. I verified the python process as suggested by the error message. Please note, this is a 3D Printer we are using at work, but my IT said he made no changes to the network when the disconnects started to occur.
- Installed a clean image of Octopi 0.17.0, and updated to Octoprint 1.5.2
- Installed a clean image of Octopi 0.16.0, and did not update Octoprint.
- Installed a clean image of Octopi 0.16.0, and updated to Octoprint 1.5.2
- Was previously using an ethernet switch, and changed to direct connection with a new cable.
(Please note, the log attached below was edited to hide IP Addresses)
I don't know which device kept trying to run "404 GET", but I will check in with IT when I find out.
octoprint.log (3.1 MB)
Raspberry Pi 3B, Ender 3 Printer with latest Marlin, I don't have much knowledge with the network since it is maintained by IT.
