Jannes
March 9, 2024, 12:05am
1
When I want to connect Octoprint with Cura it says "Octoprint is not available."
Turn plugins on and off, change Baudrate.
Yes
Yes it was connecting correctly.
You can download this in OctoPrint's System Information dialog ... no bundle, no support! )
Octoprint version 1.9.3
The log of Octoprint:
octoprint (9).log (6.0 KB)
I had major problems connecting with Cura and finally settled on this 'bulletproof' solution.
Never start or login to the printer from Cura (didn't work for me).
Open a browser and login to Octoprint.
Connect to your printer with Octoprint
Octoprint should now report the 'State' as operational
Start Cura (make sure to have the Octoprint plugin installed)
Slice a model and select 'Print with Octoprint'
Check the Octoprint screen in your browser for increasing bed and extruder temperature
This works for me every time and hopefully for you too.
Jannes
March 15, 2024, 5:54am
3
I've always done it that way. 4 months ago everything worked fine, but now Cura no longer gets a connection to Octoprint, but when I run Octoprint in safe mode, the connection works again
Could you please attach the systeminfo bundle to your next post .
The octoprint.log in your first post seems to be crippled and not complete.
system
Closed
June 13, 2024, 7:13am
5
