When I print via octoprint on my Anet AM8 (Marlin 2.0.5.3) it seems to ignore the speed settings, this is causing a jump and offset between layers because of the high speed.
My Anet was printing fine, I didn't install any plugin, so I saw that there were some updates available, I updated my Octoprint version to the lastest, as well as my installed plugins but I got no luck, the problem persists, I generated another gcode file with a lower speed and the problem is the same, also I have printed object in my SD that I have printed already and they have the same issue.
I took a look at the logs but I could't find anything.
### Complete Logs
octoprint.log
2020-08-04 19:37:08,922 - octoprint.startup - INFO - ******************************************************************************
2020-08-04 19:37:08,924 - octoprint.startup - INFO - Starting OctoPrint 1.4.1
2020-08-04 19:37:08,925 - octoprint.startup - INFO - ******************************************************************************
2020-08-04 19:37:09,629 - octoprint.util.connectivity.connectivity_checker - INFO - Connectivity changed from offline to online
2020-08-04 19:37:09,743 - octoprint.util.connectivity.connectivity_checker - INFO - Connectivity state is currently: online
2020-08-04 19:37:09,744 - octoprint.util.connectivity.connectivity_checker - INFO - Connecting to 8.8.8.8:53 is working
2020-08-04 19:37:09,745 - octoprint.util.connectivity.connectivity_checker - INFO - Resolving octoprint.org is working
2020-08-04 19:37:10,405 - octoprint.startup - INFO - Blacklist processing done, adding 1 blacklisted plugin versions: roomtemp (any)
2020-08-04 19:37:10,474 - octoprint.plugin.core - INFO - Loading plugins from /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins, /home/pi/.octoprint/plugins and installed plugin packages...
2020-08-04 19:37:12,326 - octoprint.plugin.core - INFO - Plugin Bed Visualizer (0.1.14) is disabled.
2020-08-04 19:37:12,356 - octoprint.plugin.core - INFO - Found 22 plugin(s) providing 21 mixin implementations, 47 hook handlers
2020-08-04 19:37:12,490 - octoprint.server.heartbeat - INFO - Starting server heartbeat, 900.0s interval
2020-08-04 19:37:12,517 - octoprint.server - INFO - Intermediary server started
2020-08-04 19:37:12,518 - octoprint.plugin.core - INFO - Loading plugins from /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins, /home/pi/.octoprint/plugins and installed plugin packages...
2020-08-04 19:37:12,666 - octoprint.plugin.core - INFO - Found 22 plugin(s) providing 21 mixin implementations, 47 hook handlers
2020-08-04 19:37:12,702 - octoprint.filemanager.storage - INFO - Initializing the file metadata for /home/pi/.octoprint/uploads...
2020-08-04 19:37:13,180 - octoprint.filemanager.storage - INFO - ... file metadata for /home/pi/.octoprint/uploads initialized successfully.
2020-08-04 19:37:13,185 - octoprint.server - INFO - Added new permission from plugin action_command_notification: PLUGIN_ACTION_COMMAND_NOTIFICATION_SHOW (needs: u"Need(method='role', value=u'plugin_action_command_notification_show')")
2020-08-04 19:37:13,186 - octoprint.server - INFO - Added new permission from plugin action_command_notification: PLUGIN_ACTION_COMMAND_NOTIFICATION_CLEAR (needs: u"Need(method='role', value=u'plugin_action_command_notification_clear')")
2020-08-04 19:37:13,187 - octoprint.server - INFO - Added new permission from plugin action_command_prompt: PLUGIN_ACTION_COMMAND_PROMPT_INTERACT (needs: u"Need(method='role', value=u'plugin_action_command_prompt_interact')")
2020-08-04 19:37:13,189 - octoprint.server - INFO - Added new permission from plugin announcements: PLUGIN_ANNOUNCEMENTS_READ (needs: u"Need(method='role', value=u'plugin_announcements_read')")
2020-08-04 19:37:13,191 - octoprint.server - INFO - Added new permission from plugin announcements: PLUGIN_ANNOUNCEMENTS_MANAGE (needs: u"Need(method='role', value=u'plugin_announcements_manage'), Need(method='role', value=u'plugin_announcements_read')")
2020-08-04 19:37:13,193 - octoprint.server - INFO - Added new permission from plugin appkeys: PLUGIN_APPKEYS_ADMIN (needs: u"Need(method='role', value=u'plugin_appkeys_admin')")
2020-08-04 19:37:13,194 - octoprint.server - INFO - Added new permission from plugin backup: PLUGIN_BACKUP_ACCESS (needs: u"Need(method='role', value=u'plugin_backup_access')")
2020-08-04 19:37:13,196 - octoprint.server - INFO - Added new permission from plugin firmware_check: PLUGIN_FIRMWARE_CHECK_DISPLAY (needs: u"Need(method='role', value=u'plugin_firmware_check_display')")
2020-08-04 19:37:13,197 - octoprint.server - INFO - Added new permission from plugin logging: PLUGIN_LOGGING_MANAGE (needs: u"Need(method='role', value=u'plugin_logging_manage')")
2020-08-04 19:37:13,199 - octoprint.server - INFO - Added new permission from plugin pi_support: PLUGIN_PI_SUPPORT_STATUS (needs: u"Need(method='role', value=u'plugin_pi_support_check')")
2020-08-04 19:37:13,200 - octoprint.server - INFO - Added new permission from plugin pluginmanager: PLUGIN_PLUGINMANAGER_MANAGE (needs: u"Need(method='role', value=u'plugin_pluginmanager_manage')")
2020-08-04 19:37:13,202 - octoprint.server - INFO - Added new permission from plugin pluginmanager: PLUGIN_PLUGINMANAGER_INSTALL (needs: u"Need(method='role', value=u'plugin_pluginmanager_install'), Need(method='role', value=u'plugin_pluginmanager_manage')")
2020-08-04 19:37:13,205 - octoprint.server - INFO - Added new permission from plugin softwareupdate: PLUGIN_SOFTWAREUPDATE_CHECK (needs: u"Need(method='role', value=u'plugin_softwareupdate_check')")
2020-08-04 19:37:13,206 - octoprint.server - INFO - Added new permission from plugin softwareupdate: PLUGIN_SOFTWAREUPDATE_UPDATE (needs: u"Need(method='role', value=u'plugin_softwareupdate_update')")
2020-08-04 19:37:13,224 - octoprint.access.users - INFO - Migrating user mvii3iv to new granular permission system
2020-08-04 19:37:13,249 - octoprint.printer.standard - INFO - Using print time estimator provided by PrintTimeGenius
2020-08-04 19:37:13,291 - octoprint.plugins.softwareupdate - INFO - Version cache was created for another version of OctoPrint, not using it
2020-08-04 19:37:14,409 - octoprint.util.pip - INFO - Using "/home/pi/oprint/bin/python2 -m pip" as command to invoke pip
2020-08-04 19:37:15,563 - octoprint.util.pip - INFO - Version of pip is 19.3.1
2020-08-04 19:37:15,565 - octoprint.util.pip - INFO - pip installs to /home/pi/oprint/lib/python2.7/site-packages (writable -> yes), --user flag needed -> no, virtual env -> yes
2020-08-04 19:37:15,566 - octoprint.util.pip - INFO - ==> pip ok -> yes
2020-08-04 19:37:15,573 - octoprint.plugin.core - INFO - Initialized 21 plugin implementation(s)
2020-08-04 19:37:16,080 - octoprint.plugin.core - INFO - 22 plugin(s) registered with the system:
| Action Command Notification Support (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/action_command_notification
| !Bed Visualizer (0.1.14) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_bedlevelvisualizer
| File Check (2020.7.6) (bundled) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_file_check
| Firmware Check (2020.6.22) (bundled) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_firmware_check
| GCode Viewer (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/gcodeviewer
| Login UI (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/loginui
| Octolapse (0.4.0) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_octolapse
| PrintTimeGenius Plugin (2.2.5) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_PrintTimeGenius
| Themeify (1.2.2) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_themeify
2020-08-04 19:37:16,098 - octoprint.environment - INFO - Detected environment is Python 2.7.16 under Linux (linux2). Details:
| hardware:
| cores: 4
| freq: 1200.0
| ram: 917016576
| os:
| platform: linux2
| plugins:
| pi_support:
| octopi_version: 0.17.0
| python:
| pip: 19.3.1
| version: 2.7.16
| virtualenv: /home/pi/oprint
2020-08-04 19:37:16,113 - octoprint.server - INFO - Reset webasset folder /home/pi/.octoprint/generated/webassets...
2020-08-04 19:37:16,140 - octoprint.server - INFO - Reset webasset folder /home/pi/.octoprint/generated/.webassets-cache...
2020-08-04 19:37:18,031 - octoprint.server - INFO - Shutting down intermediary server...
2020-08-04 19:37:18,393 - octoprint.server - INFO - Intermediary server shut down
2020-08-04 19:37:18,397 - octoprint.events - INFO - Processing startup event, this is our first event
2020-08-04 19:37:18,402 - octoprint.events - INFO - Adding 1 events to queue that were held back before startup event
2020-08-04 19:37:18,407 - octoprint.filemanager - INFO - Adding backlog items from all storage types to analysis queue...
2020-08-04 19:37:18,437 - octoprint.filemanager - INFO - Added 0 items from storage type "local" to analysis queue
2020-08-04 19:37:18,437 - octoprint.server.util.watchdog - INFO - Running initial scan on watched folder...
2020-08-04 19:37:18,517 - octoprint.plugins.pluginmanager - INFO - Loaded plugin repository data from disk, was still valid
2020-08-04 19:37:18,522 - octoprint.server.util.watchdog - INFO - ... initial scan done.
2020-08-04 19:37:20,862 - octoprint.plugins.pluginmanager - INFO - Loaded notice data from disk, was still valid
2020-08-04 19:37:22,319 - octoprint.util.pip - INFO - Using "/home/pi/oprint/bin/python2 -m pip" as command to invoke pip
2020-08-04 19:37:22,414 - octoprint.plugins.discovery - INFO - Registered 'OctoPrint instance on octopi' for _http._tcp
2020-08-04 19:37:22,438 - octoprint.plugins.discovery - INFO - Registered 'OctoPrint instance on octopi' for _octoprint._tcp
2020-08-04 19:37:22,460 - octoprint.plugins.discovery - INFO - Registered OctoPrint instance on octopi for SSDP
2020-08-04 19:37:22,555 - octoprint.util.pip - INFO - Using "/home/pi/oprint/bin/python2 -m pip" as command to invoke pip
2020-08-04 19:37:22,558 - octoprint.util.pip - INFO - Using "/home/pi/oprint/bin/python2 -m pip" as command to invoke pip
2020-08-04 19:37:22,596 - octoprint.server - INFO - Listening on http://127.0.0.1:5000
2020-08-04 19:37:22,845 - octoprint.plugins.pluginmanager - INFO - Loaded plugin repository data from disk, was still valid
2020-08-04 19:37:23,137 - octoprint.util.pip - INFO - Using "/home/pi/oprint/bin/python2 -m pip" as command to invoke pip
2020-08-04 19:37:23,139 - octoprint.util.pip - INFO - Using "/home/pi/oprint/bin/python2 -m pip" as command to invoke pip
2020-08-04 19:37:24,272 - octoprint.util.pip - INFO - Using "/home/pi/oprint/bin/python2 -m pip" as command to invoke pip
2020-08-04 19:37:25,102 - octoprint.plugins.pluginmanager - INFO - Loaded notice data from disk, was still valid
2020-08-04 19:37:25,229 - tornado.access - WARNING - 409 GET /api/printer (::ffff:192.168.0.116) 11.85ms
2020-08-04 19:37:25,676 - tornado.access - WARNING - 409 GET /api/printer (::ffff:192.168.0.116) 11.68ms
2020-08-04 19:37:25,795 - octoprint.server.util.sockjs - INFO - New connection from client: ::ffff:192.168.0.116
2020-08-04 19:37:25,867 - tornado.access - WARNING - 409 GET /api/printer (::ffff:192.168.0.116) 11.08ms
2020-08-04 19:37:25,927 - octoprint.server.util.flask - INFO - Passively logging in user _api from ::ffff:192.168.0.116
2020-08-04 19:37:25,931 - octoprint.access.users - INFO - Logged in user: _api
2020-08-04 19:37:26,042 - octoprint.util.comm - INFO - Changing monitoring state from "Offline" to "Detecting serial connection"
2020-08-04 19:37:26,103 - octoprint.util.comm - INFO - Serial detection: Performing autodetection with 7 port/baudrate candidates: /dev/ttyUSB0@115200, /dev/ttyUSB0@250000, /dev/ttyUSB0@230400, /dev/ttyUSB0@57600, /dev/ttyUSB0@38400, /dev/ttyUSB0@19200, /dev/ttyUSB0@9600
2020-08-04 19:37:26,105 - octoprint.util.comm - INFO - Serial detection: Trying port /dev/ttyUSB0, baudrate 115200
2020-08-04 19:37:26,107 - octoprint.util.comm - INFO - Connecting to port /dev/ttyUSB0, baudrate 115200
2020-08-04 19:37:26,119 - octoprint.util.comm - INFO - Serial detection: Handshake attempt #1 with timeout 2.0s
2020-08-04 19:37:26,124 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2020-08-04 19:37:26,341 - octoprint.util.pip - INFO - pip installs to /home/pi/oprint/lib/python2.7/site-packages/ (writable -> yes), --user flag needed -> no, virtual env -> yes
2020-08-04 19:37:26,342 - octoprint.util.pip - INFO - ==> pip ok -> yes
2020-08-04 19:37:26,353 - octoprint.util.pip - INFO - pip installs to /home/pi/oprint/lib/python2.7/site-packages (writable -> yes), --user flag needed -> no, virtual env -> yes
2020-08-04 19:37:26,359 - octoprint.util.pip - INFO - ==> pip ok -> yes
2020-08-04 19:37:26,372 - octoprint.plugins.softwareupdate - INFO - Minimum free storage across all update relevant locations is 11.7GB. That is considered sufficient for updating.
2020-08-04 19:37:27,008 - octoprint.plugins.softwareupdate - INFO - Saved version cache to disk
2020-08-04 19:37:27,020 - octoprint.plugins.themeify - INFO - Themeify initialized.
2020-08-04 19:37:27,185 - octoprint.server.preemptive_cache - INFO - Preemptively caching / (ui _default) for {'query_string': 'l10n=en', 'path': '/', 'base_url': 'http://octopi.local/'}
2020-08-04 19:37:27,731 - octoprint.plugins.tracking - INFO - Sent tracking event ping, payload: {'octoprint_uptime': 15}
2020-08-04 19:37:27,795 - octoprint.util.comm - INFO - Changing monitoring state from "Detecting serial connection" to "Operational"
2020-08-04 19:37:27,808 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2020-08-04 19:37:28,391 - octoprint.plugins.tracking - INFO - Sent tracking event startup, payload: {'python': '2.7.16', 'ram': 917016576, u'octopi_version': u'0.17.0', 'version': u'1.4.1', 'pip': '19.3.1', 'cores': 4, 'freq': 1200.0, u'pi_model': u'Raspberry Pi 3 Model B Rev 1.2', 'os': 'linux'}
2020-08-04 19:37:29,216 - octoprint.plugins.tracking - INFO - Sent tracking event pong, payload: {'python': '2.7.16', 'ram': 917016576, u'octopi_version': u'0.17.0', 'version': u'1.4.1', u'plugins': u'octolapse:0.4.0,themeify:1.2.2,printtimegenius:2.2.5', 'pip': '19.3.1', 'cores': 4, 'freq': 1200.0, u'pi_model': u'Raspberry Pi 3 Model B Rev 1.2', 'os': 'linux'}
2020-08-04 19:37:30,105 - tornado.access - WARNING - 403 GET /api/settings (::ffff:192.168.0.116) 176.70ms
2020-08-04 19:37:30,130 - tornado.access - WARNING - 403 GET /api/files?recursive=true (::ffff:192.168.0.116) 18.14ms
2020-08-04 19:37:30,155 - tornado.access - WARNING - 403 GET /api/plugin/pi_support (::ffff:192.168.0.116) 19.59ms
2020-08-04 19:37:30,187 - tornado.access - WARNING - 403 GET /api/timelapse?unrendered=true (::ffff:192.168.0.116) 21.48ms
2020-08-04 19:37:30,311 - tornado.access - WARNING - 403 POST /plugin/octolapse/loadState (::ffff:192.168.0.116) 149.84ms
2020-08-04 19:37:30,319 - octoprint.server.util.sockjs - INFO - Client connection closed: ::ffff:192.168.0.116
2020-08-04 19:37:30,947 - octoprint.server.util.sockjs - INFO - New connection from client: ::ffff:192.168.0.116
2020-08-04 19:37:31,065 - octoprint.util.comm - INFO - Printer reports firmware name "Marlin 2.0.5.3 (GitHub)"
2020-08-04 19:37:31,100 - octoprint.util.comm - INFO - Firmware states that it supports temperature autoreporting
2020-08-04 19:37:31,965 - octoprint.plugins.tracking - INFO - Sent tracking event printer_connected, payload: {u'printer_baudrate': 0, u'printer_port': None, 'firmware_name': u'Marlin 2.0.5.3 (GitHub)'}
2020-08-04 19:37:38,203 - tornado.access - WARNING - 404 POST /api/plugin/zbolt_octoscreen (127.0.0.1) 15.79ms
2020-08-04 19:37:38,224 - tornado.access - WARNING - 404 POST /api/plugin/zbolt_octoscreen (127.0.0.1) 15.81ms
2020-08-04 19:37:41,109 - octoprint.server.preemptive_cache - INFO - ... done in 13.92s
2020-08-04 19:37:41,110 - octoprint.server.preemptive_cache - INFO - Preemptively caching / (ui _default) for {'query_string': 'l10n=en', 'path': '/', 'base_url': 'http://192.168.0.117/'}
2020-08-04 19:37:41,704 - octoprint.server.preemptive_cache - INFO - ... done in 0.59s
2020-08-04 19:38:19,684 - octoprint.access.users - INFO - Logged in user: mvii3iv
2020-08-04 19:38:19,692 - octoprint.server.api - INFO - Actively logging in user mvii3iv from ::ffff:192.168.0.116
2020-08-04 19:38:19,799 - octoprint.server.util.flask - INFO - Passively logging in user mvii3iv from ::ffff:192.168.0.116
2020-08-04 19:38:19,801 - octoprint.access.users - INFO - Logged in user: mvii3iv
2020-08-04 19:38:19,959 - octoprint.server.util.sockjs - INFO - Client connection closed: ::ffff:192.168.0.116
2020-08-04 19:38:23,494 - octoprint.server.util.sockjs - INFO - New connection from client: ::ffff:192.168.0.116
2020-08-04 19:38:23,582 - octoprint.server.util.flask - INFO - Passively logging in user mvii3iv from ::ffff:192.168.0.116
2020-08-04 19:38:23,585 - octoprint.access.users - INFO - Logged in user: mvii3iv
2020-08-04 19:38:27,133 - octoprint.server.util.sockjs - INFO - User mvii3iv logged in on the socket from client ::ffff:192.168.0.116
2020-08-04 19:48:00,710 - octoprint.server.util.flask - INFO - Passively logging in user mvii3iv from ::ffff:192.168.0.116
2020-08-04 19:48:00,713 - octoprint.access.users - INFO - Logged in user: mvii3iv
2020-08-04 19:48:00,898 - octoprint.server.util.sockjs - INFO - Client connection closed: ::ffff:192.168.0.116
2020-08-04 19:48:05,068 - octoprint.server.util.sockjs - INFO - New connection from client: ::ffff:192.168.0.116
2020-08-04 19:48:05,199 - octoprint.server.util.flask - INFO - Passively logging in user mvii3iv from ::ffff:192.168.0.116
2020-08-04 19:48:05,203 - octoprint.access.users - INFO - Logged in user: mvii3iv
2020-08-04 19:48:07,667 - octoprint.server.util.sockjs - INFO - User mvii3iv logged in on the socket from client ::ffff:192.168.0.116
2020-08-04 19:52:12,492 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2020-08-04 19:52:27,680 - octoprint.plugins.tracking - INFO - Sent tracking event ping, payload: {'octoprint_uptime': 915}
2020-08-04 20:01:36,103 - octoprint.printer.standard.job - INFO - Print job selected - origin: local, path: Phone_Stand03.gcode, owner: mvii3iv, user: mvii3iv
2020-08-04 20:01:36,128 - octoprint.util.comm - INFO - Changing monitoring state from "Operational" to "Starting"
2020-08-04 20:01:36,141 - octoprint.printer.standard.job - INFO - Print job started - origin: local, path: Phone_Stand03.gcode, owner: mvii3iv, user: mvii3iv
2020-08-04 20:01:36,200 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2020-08-04 20:01:36,228 - octoprint.util.comm - INFO - Changing monitoring state from "Starting" to "Printing"
2020-08-04 20:01:36,881 - octoprint.plugins.tracking - INFO - Sent tracking event print_started, payload: {'origin': u'local', 'file': '51ec470b9a1e78626c3233a884ba9fdc532fed87'}
2020-08-04 20:06:54,452 - octoprint.util.comm - INFO - Changing monitoring state from "Printing" to "Cancelling"
2020-08-04 20:06:54,468 - octoprint.printer.standard.job - INFO - Print job cancelled - origin: local, path: Phone_Stand03.gcode, owner: mvii3iv, user: _api
2020-08-04 20:06:55,159 - octoprint.util.comm - INFO - Changing monitoring state from "Cancelling" to "Operational"
2020-08-04 20:06:55,285 - octoprint.plugins.tracking - INFO - Sent tracking event print_cancelled, payload: {'origin': u'local', 'file': '51ec470b9a1e78626c3233a884ba9fdc532fed87', u'elapsed': 318}
2020-08-04 20:06:55,941 - octoprint.plugins.tracking - INFO - Sent tracking event print_failed, payload: {'origin': u'local', u'reason': u'cancelled', 'file': '51ec470b9a1e78626c3233a884ba9fdc532fed87', u'elapsed': 318}
2020-08-04 20:07:12,493 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2020-08-04 20:07:27,686 - octoprint.plugins.tracking - INFO - Sent tracking event ping, payload: {'octoprint_uptime': 1815}
Anet A8 (Marlin 2.0.5.3)
OctoPrint version : 1.4.1
OctoPi version : 0.17.0
PLUGINS
- Octolapse
- PrintTimeGenius Plugin
- Printer Dialogs
- Printer Notifications
- Themeify
- Virtual Printer
Sorry if I missed something important, this is my first post here.
