Edit: I think it was probably the OctoLapse update. I’m going to test and post again if that wasn’t the case, but I’m sure it couldn’t be anything else.
So I haven’t printed in a week because of some printer upgrades I was working on. I had not touch OP since then. But I just started a calibration cube and OP is sending this command to the printer after every layer:
Send: N16 G0 X110.000 Y110.000 F12000.000*84
That command doesn’t exist in the GCode. Also, I have a start GCode script in OP that draws a line back to front along the right side, moves over a little, and draw a line going back. It issues that command betwee those 2 commands. And that command definitely isn’t in that start GCode. Doesn’t anyone have any ideas as to why this happens?
