Hello,
I am configuring 2nd camera Logitech C270 but when I connect to PI3 I get following errors:
pi@octopi:~ $ tail -F /var/log/messages
Nov 17 23:38:14 octopi kernel: [ 221.144592] uvcvideo 1-1.5.1:1.0: Entity type for entity Extension 4 was not initialized!
Nov 17 23:38:14 octopi kernel: [ 221.144611] uvcvideo 1-1.5.1:1.0: Entity type for entity Extension 6 was not initialized!
Nov 17 23:38:14 octopi kernel: [ 221.144649] uvcvideo 1-1.5.1:1.0: Entity type for entity Extension 7 was not initialized!
Nov 17 23:38:14 octopi kernel: [ 221.144660] uvcvideo 1-1.5.1:1.0: Entity type for entity Processing 2 was not initialized!
Nov 17 23:38:14 octopi kernel: [ 221.144670] uvcvideo 1-1.5.1:1.0: Entity type for entity Extension 3 was not initialized!
Nov 17 23:38:14 octopi kernel: [ 221.144680] uvcvideo 1-1.5.1:1.0: Entity type for entity Camera 1 was not initialized!
Nov 17 23:38:14 octopi kernel: [ 221.145641] input: UVC Camera (046d:0825) as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.5/1-1.5.1/1-1.5.1:1.0/input/input2
Nov 17 23:38:16 octopi kernel: [ 222.484252] usb 1-1.5.1: set resolution quirk: cval->res = 384
Nov 17 23:38:16 octopi mtp-probe: checking bus 1, device 10: "/sys/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.5/1-1.5.1"
Nov 17 23:38:16 octopi mtp-probe: bus: 1, device: 10 was not an MTP device
Nov 17 23:38:42 octopi kernel: [ 249.087371] usb 1-1.5.1: USB disconnect, device number 10
Nov 17 23:38:43 octopi pi: Starting USB webcam
Nov 17 23:38:43 octopi MJPG-streamer [1106]: starting application
Nov 17 23:38:43 octopi MJPG-streamer [1106]: MJPG Streamer Version: git rev: 821c330ea6bbb5fbed98d48e00aac156e923161b
Nov 17 23:38:43 octopi MJPG-streamer [1106]: Using V4L2 device.: /dev/ttyUSB2
Nov 17 23:38:43 octopi MJPG-streamer [1106]: Desired Resolution: 640 x 480
Nov 17 23:38:43 octopi MJPG-streamer [1106]: Frames Per Second.: 10
Nov 17 23:38:43 octopi MJPG-streamer [1106]: Format............: JPEG
Nov 17 23:38:43 octopi MJPG-streamer [1106]: TV-Norm...........: DEFAULT
Nov 17 23:38:43 octopi MJPG-streamer [1106]: init_VideoIn failed
Nov 17 23:38:43 octopi MJPG-streamer [1124]: starting application
Nov 17 23:38:43 octopi MJPG-streamer [1124]: MJPG Streamer Version: git rev: 821c330ea6bbb5fbed98d48e00aac156e923161b
Nov 17 23:38:43 octopi MJPG-streamer [1124]: Using V4L2 device.: /dev/video0
Nov 17 23:38:43 octopi MJPG-streamer [1124]: Desired Resolution: 1920 x 1080
Nov 17 23:38:43 octopi MJPG-streamer [1124]: Frames Per Second.: 10
Nov 17 23:38:43 octopi MJPG-streamer [1124]: Format............: JPEG
Nov 17 23:38:43 octopi MJPG-streamer [1124]: TV-Norm...........: DEFAULT
Nov 17 23:38:43 octopi MJPG-streamer [1124]: init_VideoIn failed
Nov 17 23:39:05 octopi kernel: [ 272.170004] usb 1-1.5.1: new high-speed USB device number 11 using dwc_otg
Nov 17 23:39:06 octopi kernel: [ 272.512121] usb 1-1.5.1: New USB device found, idVendor=046d, idProduct=0825
Nov 17 23:39:06 octopi kernel: [ 272.512137] usb 1-1.5.1: New USB device strings: Mfr=0, Product=0, SerialNumber=2
Nov 17 23:39:06 octopi kernel: [ 272.512146] usb 1-1.5.1: SerialNumber: AB890690
Nov 17 23:39:06 octopi kernel: [ 272.513199] uvcvideo: Found UVC 1.00 device (046d:0825)
Nov 17 23:39:06 octopi kernel: [ 272.602996] uvcvideo 1-1.5.1:1.0: Entity type for entity Extension 4 was not initialized!
Nov 17 23:39:06 octopi kernel: [ 272.603014] uvcvideo 1-1.5.1:1.0: Entity type for entity Extension 6 was not initialized!
Nov 17 23:39:06 octopi kernel: [ 272.603025] uvcvideo 1-1.5.1:1.0: Entity type for entity Extension 7 was not initialized!
Nov 17 23:39:06 octopi kernel: [ 272.603037] uvcvideo 1-1.5.1:1.0: Entity type for entity Processing 2 was not initialized!
Nov 17 23:39:06 octopi kernel: [ 272.603046] uvcvideo 1-1.5.1:1.0: Entity type for entity Extension 3 was not initialized!
Nov 17 23:39:06 octopi kernel: [ 272.603056] uvcvideo 1-1.5.1:1.0: Entity type for entity Camera 1 was not initialized!
Nov 17 23:39:06 octopi kernel: [ 272.603532] input: UVC Camera (046d:0825) as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.5/1-1.5.1/1-1.5.1:1.0/input/input3
Nov 17 23:39:06 octopi kernel: [ 272.633878] usb 1-1.5.1: set resolution quirk: cval->res = 384
Nov 17 23:39:06 octopi mtp-probe: checking bus 1, device 11: "/sys/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.5/1-1.5.1"
Nov 17 23:39:06 octopi mtp-probe: bus: 1, device: 11 was not an MTP device
Nov 17 23:39:13 octopi pi: Starting USB webcam
Nov 17 23:39:13 octopi MJPG-streamer [1153]: starting application
Nov 17 23:39:13 octopi MJPG-streamer [1153]: MJPG Streamer Version: git rev: 821c330ea6bbb5fbed98d48e00aac156e923161b
Nov 17 23:39:13 octopi MJPG-streamer [1153]: Using V4L2 device.: /dev/ttyUSB2
Nov 17 23:39:13 octopi MJPG-streamer [1153]: Desired Resolution: 640 x 480
Nov 17 23:39:13 octopi MJPG-streamer [1153]: Frames Per Second.: 10
Nov 17 23:39:13 octopi MJPG-streamer [1153]: Format............: JPEG
Nov 17 23:39:13 octopi MJPG-streamer [1153]: TV-Norm...........: DEFAULT
Nov 17 23:39:13 octopi MJPG-streamer [1153]: init_VideoIn failed
Nov 17 23:39:13 octopi MJPG-streamer [1171]: starting application
Nov 17 23:39:13 octopi MJPG-streamer [1171]: MJPG Streamer Version: git rev: 821c330ea6bbb5fbed98d48e00aac156e923161b
Nov 17 23:39:13 octopi MJPG-streamer [1171]: Using V4L2 device.: /dev/video0
Nov 17 23:39:13 octopi MJPG-streamer [1171]: Desired Resolution: 1920 x 1080
Nov 17 23:39:13 octopi MJPG-streamer [1171]: Frames Per Second.: 10
Nov 17 23:39:13 octopi MJPG-streamer [1171]: Format............: JPEG
Nov 17 23:39:13 octopi MJPG-streamer [1171]: TV-Norm...........: DEFAULT
Nov 17 23:39:13 octopi MJPG-streamer [1171]: init_VideoIn failed
Camera is working without any problems on PC (win 10).
Any ideas how to solve that ? Other camera C920 working without any problems...
