When sending print files from Cura to Octa print my 3-D printer does not auto level like using an SD card.
Reading on the Internet
I just wanna use my cura slicer so when I send it to October print it will autolelevel before it starts printing. Just trying to find a solution any help would be appreciated
What printer do you have (make, model, firmware version)?
What steps do you take to get an .stl file ready for printing from the SD card?
What steps do you take to get an .stl file ready for printing via OctoPrint?
To expand on @PrintedWeezl's request, the commands for auto leveling are usually contained in the start gcode that the slicer inserts at the beginning of the gcode output. Transferring that gcode output to an SD card and printing it or printing it directly via OctoPrint should behave the same.
The behavior you describe would make sense if your printer does something specific (i.e. automatic auto leveling) when printing from SD.
Once we understand what is happening, we can help you fix it.
