Octoprint Not detecting my 3d printers USB connection
I have set everything out properly, but octopprint just can’t detect a serial port
I have tried adding the code to the additional serial ports box, it shows up, i can click on it, but an error message pops up when I connect it
I have not ran in it safe mode but I do not think it would work anyways, i suspect it has something to do with my 3d printers firmware.
I have installed all the newest octoprint and octopi versions, i have a rasberry pi 4B, my printer is the ELEGOO Neptune 4 pro, it runs Klipper firmware. Could it have anything to do with klipper?
Hello @Mr_Burge !
So, do you have Klipper installed on your Pi too?
Maybe a silly question.
Does your cable compatible data ?
No, I do not have klipper installed on my PI, my 3d printer comes with klipper pre-installed, would installing the octoklipper solve my problems?
yes it does, when i bought it I made sure not to make that mistake
Now for clarification:
You got a printer with Klipper on it but without a Pi that you got yourself? Or is there a Pi like SBC with that printer that runs the Klipper host?
The Neptune 4 Pro has it's own Klipper Ecosystem with Fluidd. There is no need for OctoPrint.
BTW: Klipper is a two part firmware solution. It works different than Marlin:
oohhh, ok thanks for that, i understand now.
