Unable to get OctoPrint connection to 3D printer working on /dev/ttyAMA0 after upgrading from Mate 20.04 to Mate 22.04. (Fresh install of everything done twice already) Hardware is a Creality CR6-SE with community firmware connected to Pi4 with 8GB in Argon case with 250GB SSD (Kernel Linux 5.15.0-1013-raspi aarch64)
Any help would be greatly appreciated. * * *
ERROR Log Info:
Connecting to port /dev/ttyAMA0, baudrate 115200
Serial detection: Handshake attempt #3 with timeout 2.0s
M110 detected, setting current line number to 0
Changing monitoring state from "Detecting serial connection" to "Error"
Same results running Octoprint in Safe Mode
User is a member of tty & dialout groups
Have also tried deleting tty & ttyAMA0 from the /dev directory
(Appears to have most the of same issues that accompanied having the brltty.service (Braille service) running in version 20.10, but 22.04 doesn't load the brltty.service.)
I am no expert at reading dmesg data, but nothing jumps out as a problem to me.
USB Section looked like this:
[ 2.548884] usb usb1: SerialNumber: 0000:01:00.0
[ 2.553627] hub 1-0:1.0: USB hub found
[ 2.553698] hub 1-0:1.0: 1 port detected
[ 2.554204] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ 2.554216] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
[ 2.554228] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
[ 2.554423] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.15
[ 2.554431] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.554437] usb usb2: Product: xHCI Host Controller
[ 2.554442] usb usb2: Manufacturer: Linux 5.15.0-1014-raspi xhci-hcd
[ 2.554446] usb usb2: SerialNumber: 0000:01:00.0
[ 2.568019] hub 2-0:1.0: USB hub found
[ 2.568116] hub 2-0:1.0: 4 ports detected
[ 2.573581] brcmstb-i2c fef04500.i2c: @97500hz registered in polling mode
[ 2.575172] brcmstb-i2c fef09500.i2c: @97500hz registered in polling mode
[ 2.595104] dwc2 fe980000.usb: supply vusb_d not found, using dummy regulator
[ 2.595276] dwc2 fe980000.usb: supply vusb_a not found, using dummy regulator
[ 2.615819] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 0
[ 2.807634] dwc2 fe980000.usb: EPs: 8, dedicated fifos, 4080 entries in SPRAM
[ 2.808085] dwc2 fe980000.usb: DWC OTG Controller
[ 2.809322] dwc2 fe980000.usb: new USB bus registered, assigned bus number 3
[ 2.809368] dwc2 fe980000.usb: irq 24, io mem 0xfe980000
[ 2.809540] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15
[ 2.809547] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.809553] usb usb3: Product: DWC OTG Controller
[ 2.809558] usb usb3: Manufacturer: Linux 5.15.0-1014-raspi dwc2_hsotg
[ 2.809562] usb usb3: SerialNumber: fe980000.usb
[ 2.860469] hub 3-0:1.0: USB hub found
[ 2.860531] hub 3-0:1.0: 1 port detected
[ 2.887593] usb 1-1: new high-speed USB device number 2 using xhci_hcd
[ 3.038283] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.21
[ 3.038316] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 3.038330] usb 1-1: Product: USB2.0 Hub
[ 3.040232] hub 1-1:1.0: USB hub found
[ 3.040536] hub 1-1:1.0: 4 ports detected
[ 3.163970] usb 2-2: new SuperSpeed USB device number 2 using xhci_hcd
[ 3.185341] usb 2-2: New USB device found, idVendor=174c, idProduct=1156, bcdDevice= 1.00
[ 3.185361] usb 2-2: New USB device strings: Mfr=2, Product=3, SerialNumber=1
[ 3.185374] usb 2-2: Product: Forty
[ 3.185385] usb 2-2: Manufacturer: Argon
[ 3.185396] usb 2-2: SerialNumber: 0000000000E4
[ 3.218738] usbcore: registered new interface driver usb-storage
[ 3.226952] scsi host0: uas
[ 3.227309] usbcore: registered new interface driver uas
[ 3.227844] scsi 0:0:0:0: Direct-Access Argon Forty 0 PQ: 0 ANSI: 6
[ 3.228853] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 3.229636] sd 0:0:0:0: [sda] 500118192 512-byte logical blocks: (256 GB/238 GiB)
[ 3.229645] sd 0:0:0:0: [sda] 4096-byte physical blocks
[ 3.229801] sd 0:0:0:0: [sda] Write Protect is off
[ 3.229808] sd 0:0:0:0: [sda] Mode Sense: 43 00 00 00
[ 3.230022] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 3.230603] sd 0:0:0:0: [sda] Optimal transfer size 33553920 bytes not a multiple of physical block size (4096 bytes)
[ 3.268778] sda: sda1 sda2
[ 3.284223] sd 0:0:0:0: [sda] Attached SCSI disk
[ 3.335618] usb 1-1.3: new high-speed USB device number 3 using xhci_hcd
[ 3.467206] usb 1-1.3: New USB device found, idVendor=0ac8, idProduct=3460, bcdDevice= 1.00
[ 3.467240] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 3.467253] usb 1-1.3: Product: Kodak Dual Webcamera
[ 3.467265] usb 1-1.3: Manufacturer: Sakar Corp.
[ 3.547690] usb 1-1.4: new low-speed USB device number 4 using xhci_hcd
[ 3.659542] usb 1-1.4: New USB device found, idVendor=17ef, idProduct=6019, bcdDevice= 1.00
[ 3.659562] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 3.659568] usb 1-1.4: Product: Lenovo USB Optical Mouse
[ 3.659573] usb 1-1.4: Manufacturer: PixArt
[ 3.676807] usbcore: registered new interface driver usbhid
[ 3.676823] usbhid: USB HID core driver
[ 3.687097] input: PixArt Lenovo USB Optical Mouse as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4:1.0/0003:17EF:6019.0001/input/input0
[ 3.687365] hid-generic 0003:17EF:6019.0001: input,hidraw0: USB HID v1.11 Mouse [PixArt Lenovo USB Optical Mouse] on usb-0000:01:00.0-1.4/input0
[ 3.935332] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
[ 4.471723] systemd[1]: Inserted module 'autofs4'
Not sure what you expect to see, but here is what showed up as /dev/ttyAMA0 timed out it's connection.
octoprint@Pi4-Mate:~$ sudo tail -f /var/log/syslog
Sep 11 11:35:45 Pi4-Mate dbus-daemon[839]: [system] Activating via systemd: service name='org.freedesktop.timedate1' unit='dbus-org.freedesktop.timedate1.service' requested by ':1.33' (uid=0 pid=858 comm="/usr/lib/snapd/snapd " label="unconfined")
Sep 11 11:35:45 Pi4-Mate systemd[1]: Starting Time & Date Service...
Sep 11 11:35:45 Pi4-Mate dbus-daemon[839]: [system] Successfully activated service 'org.freedesktop.timedate1'
Sep 11 11:35:45 Pi4-Mate systemd[1]: Started Time & Date Service.
Sep 11 11:36:15 Pi4-Mate systemd[1]: systemd-timedated.service: Deactivated successfully.
Sep 11 11:45:43 Pi4-Mate systemd[1]: Starting Cleanup of Temporary Directories...
Sep 11 11:45:43 Pi4-Mate systemd[1]: systemd-tmpfiles-clean.service: Deactivated successfully.
Sep 11 11:45:43 Pi4-Mate systemd[1]: Finished Cleanup of Temporary Directories.
Sep 11 11:45:52 Pi4-Mate python3[908]: 2022-09-11 11:45:52,081 - octoprint.server.heartbeat - INFO - Server heartbeat <3#033[0m
Sep 11 11:46:02 Pi4-Mate python3[908]: 2022-09-11 11:46:02,472 - octoprint.plugins.tracking - INFO - Sent tracking event ping, payload: {'octoprint_uptime': 909, 'printer_state': 'OFFLINE'}#033[0m
Sep 11 11:48:27 Pi4-Mate python3[908]: 2022-09-11 11:48:27,528 - octoprint.util.comm - INFO - Changing monitoring state from "Offline" to "Opening serial connection"#033[0m
Sep 11 11:48:27 Pi4-Mate python3[908]: 2022-09-11 11:48:27,530 - octoprint.util.comm - INFO - Connecting to port /dev/ttyAMA0, baudrate 115200#033[0m
Sep 11 11:48:27 Pi4-Mate python3[908]: 2022-09-11 11:48:27,547 - octoprint.util.comm - INFO - Changing monitoring state from "Opening serial connection" to "Connecting"#033[0m
Sep 11 11:48:27 Pi4-Mate python3[908]: 2022-09-11 11:48:27,553 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0#033[0m
Sep 11 11:48:57 Pi4-Mate python3[908]: 2022-09-11 11:48:57,589 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0#033[0m
Sep 11 11:49:07 Pi4-Mate python3[908]: 2022-09-11 11:49:07,608 - octoprint.util.comm - INFO - Changing monitoring state from "Connecting" to "Offline"#033[0m
Sep 11 11:49:07 Pi4-Mate python3[908]: 2022-09-11 11:49:07,616 - octoprint.plugins.action_command_notification - INFO - Notifications cleared#033[0m
YOU ARE 100% CORRECT in your POST!!!
I finally got there myself before reading your answer by unplugging and plugging the printer and looking at sudo dmesg results.
Looks as if your solution WORKS as suggested. But, I had tried to do `sudo systemctl disable brltty.service' and with service at the end it failed to find the service and failed to correct my problem.
The FIX I used is found at: [usbfs: interface 0 claimed by ch34x while 'brltty' sets config #1 · Issue #18 ·
From the comments it appears several others have used it successfully also.
