Hey there! My problem: when I open octoprint in my browser, I get the "server is currently not running" site.
So I installed octopi on my raspberry pi 3B+, configured it for my network and set it up.
After that, I changed the frontend port to 81 and the ssl to 444 (in haproxy.cfg) and installed apache2+wordpress+noip2 to host a website on port 80.
Then I wanted to log in to octopi on port 81 but after reloading I always got this site " The OctoPrint server is currently not running".
I followed the steps and tried this command: "pi@octopi:~ $ ps -ef | grep -i octoprint | grep -i python" and got no output.'
.octoprint/logs/octoprint.log says:
octoprint.server.heartbeat - INFO - Server heartbeat <3
octoprint.server - INFO - --- Log roll over detected ---------------------------------------------------
octoprint.server - INFO - OctoPrint 1.3.10
octoprint.plugin.core - INFO - 15 plugin(s) registered with the system:
| CuraEngine (<= 15.04) (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/cura
2019-08-23 16:51:51,549 - octoprint.environment - INFO - Detected environment is Python 2.7.13 under Linux (linux2). Details:
| hardware:
| cores: 4
| freq: 1400.0
| ram: 918188032
| os:
| platform: linux2
| plugins:
| pi_support:
| model: Raspberry Pi 3 Model B Plus Rev 1.3
| octopi_version: 0.16.0
| python:
| pip: 19.0.1
| version: 2.7.13
| virtualenv: /home/pi/oprint
octoprint.server - INFO - ------------------------------------------------------------------------------
octoprint.plugins.announcements - INFO - Loaded channel _octopi from https://octoprint.org/feeds/octopi.xml in 2.4e+07s
2019-08-23 16:51:55,649 - octoprint.util.pip - INFO - Using "/home/pi/oprint/bin/python2 -m pip" as command to invoke pip
2019-08-23 16:52:00,971 - octoprint.server.util.flask.PreemptiveCache - INFO - Adding entry for / and {'query_string': 'l10n=de', 'path': u'/', '_count': 1, '_timestamp': 1566575520.971097, 'base_url': 'http://192.168.0.135/'}
2019-08-23 16:52:01,621 - octoprint.util.pip - INFO - pip installs to /home/pi/oprint/lib/python2.7/site-packages/ (writable -> yes), --user flag needed -> no, virtual env -> yes
2019-08-23 16:52:01,621 - octoprint.util.pip - INFO - ==> pip ok -> yes
2019-08-23 16:52:01,642 - octoprint.plugins.softwareupdate - INFO - Saved version cache to disk
2019-08-23 16:52:01,675 - octoprint.server.preemptive_cache - INFO - Preemptively caching / (ui _default) for {'query_string': 'l10n=de', 'path': '/', 'base_url': 'http://192.168.0.135/'}
2019-08-23 16:52:16,149 - octoprint.server.preemptive_cache - INFO - ... done in 14.47s
2019-08-23 16:52:20,230 - octoprint.server.util.sockjs - INFO - New connection from client: ::ffff:192.168.0.129
2019-08-23 16:54:02,645 - octoprint.server.api - INFO - Actively logging in user Mitschael from ::ffff:192.168.0.129
2019-08-23 16:54:03,407 - octoprint.plugins.announcements - INFO - Loaded channel _important from https://octoprint.org/feeds/important.xml in 0.34s
2019-08-23 16:54:03,942 - octoprint.plugins.announcements - INFO - Loaded channel _releases from https://octoprint.org/feeds/releases.xml in 0.28s
2019-08-23 16:54:04,360 - octoprint.plugins.announcements - INFO - Loaded channel _blog from https://octoprint.org/feeds/octoblog.xml in 0.29s
2019-08-23 16:54:04,763 - octoprint.plugins.announcements - INFO - Loaded channel _plugins from https://plugins.octoprint.org/feed.xml in 0.34s
2019-08-23 16:54:05,758 - octoprint.server.util.sockjs - INFO - User Mitschael logged in on the socket from client ::ffff:192.168.0.129
2019-08-23 16:54:11,638 - octoprint.plugins.tracking - INFO - Initialized anonymous tracking
2019-08-23 16:54:12,174 - octoprint.plugins.tracking - INFO - Sent tracking event startup, payload: {'python': '2.7.13', 'ram': 918188032, 'octopi_version': '0.16.0', 'version': u'1.3.10', 'pip': '19.0.1', 'cores': 4, 'freq': 1400.0, 'p$
2019-08-23 16:55:39,162 - octoprint.startup - INFO - ******************************************************************************
2019-08-23 16:55:39,164 - octoprint.startup - INFO - Starting OctoPrint 1.3.10
2019-08-23 16:55:39,166 - octoprint.startup - INFO - ******************************************************************************
2019-08-23 16:55:40,273 - octoprint.startup - INFO - We don't appear to be online, not fetching plugin blacklist
2019-08-23 16:55:40,364 - octoprint.plugin.core - INFO - Loading plugins from /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins, /home/pi/.octoprint/plugins and installed plugin packages...
2019-08-23 16:55:42,748 - octoprint.plugin.core - INFO - Found 15 plugin(s) providing 15 mixin implementations, 17 hook handlers
2019-08-23 16:55:42,868 - octoprint.server.heartbeat - INFO - Starting server heartbeat, 900.0s interval
2019-08-23 16:55:42,916 - octoprint.server - INFO - Intermediary server started
2019-08-23 16:55:42,916 - octoprint.plugin.core - INFO - Loading plugins from /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins, /home/pi/.octoprint/plugins and installed plugin packages...
2019-08-23 16:55:43,438 - octoprint.plugin.core - INFO - Found 15 plugin(s) providing 15 mixin implementations, 17 hook handlers
2019-08-23 16:55:43,475 - octoprint.filemanager.storage - INFO - Initializing the file metadata for /home/pi/.octoprint/uploads...
2019-08-23 16:55:43,476 - octoprint.filemanager.storage - INFO - ... file metadata for /home/pi/.octoprint/uploads initialized successfully.
2019-08-23 16:55:43,493 - octoprint.plugins.tracking - INFO - Initialized anonymous tracking
2019-08-23 16:55:43,526 - octoprint.plugins.softwareupdate - INFO - Loaded version cache from disk
2019-08-23 16:55:45,468 - octoprint.util.pip - INFO - Using "/home/pi/oprint/bin/python2 -m pip" as command to invoke pip
2019-08-23 16:55:46,888 - octoprint.util.pip - INFO - Version of pip is 19.0.1
2019-08-23 16:55:46,890 - octoprint.util.pip - INFO - pip installs to /home/pi/oprint/lib/python2.7/site-packages (writable -> yes), --user flag needed -> no, virtual env -> yes
2019-08-23 16:55:46,890 - octoprint.util.pip - INFO - ==> pip ok -> yes
2019-08-23 16:55:46,895 - octoprint.plugin.core - INFO - Initialized 15 plugin implementation(s)
2019-08-23 16:55:46,905 - octoprint.plugin.core - INFO - 15 plugin(s) registered with the system:
2019-08-23 16:55:46,923 - octoprint.environment - INFO - Detected environment is Python 2.7.13 under Linux (linux2). Details:
| hardware:
| cores: 4
| freq: 1400.0
| ram: 918188032
| os:
| platform: linux2
| plugins:
| pi_support:
| python:
| pip: 19.0.1
| version: 2.7.13
2019-08-23 16:55:46,932 - octoprint.server - INFO - Reset webasset folder /home/pi/.octoprint/generated/webassets...
2019-08-23 16:55:46,946 - octoprint.server - INFO - Reset webasset folder /home/pi/.octoprint/generated/.webassets-cache...
2019-08-23 16:55:47,300 - octoprint.server - INFO - Shutting down intermediary server...
2019-08-23 16:55:47,443 - octoprint.server - INFO - Intermediary server shut down
2019-08-23 16:55:47,447 - octoprint.events - INFO - Processing startup event, this is our first event
2019-08-23 16:55:47,449 - octoprint.events - INFO - Adding 0 events to queue that were held back before startup event
2019-08-23 16:55:47,455 - octoprint.filemanager - INFO - Adding backlog items from all storage types to analysis queue...
2019-08-23 16:55:47,465 - octoprint.filemanager - INFO - Added 0 items from storage type "local" to analysis queue
2019-08-23 16:55:47,477 - octoprint.plugins.discovery - INFO - Registered 'OctoPrint instance on octopi' for _http._tcp
2019-08-23 16:55:47,488 - octoprint.plugins.discovery - INFO - Registered 'OctoPrint instance on octopi' for _octoprint._tcp
2019-08-23 16:55:47,509 - octoprint.server - INFO - Listening on http://127.0.0.1:5000
2019-08-23 16:55:47,518 - octoprint.plugins.pluginmanager - INFO - Looks like we are offline, can't fetch repository from network
2019-08-23 16:55:47,519 - octoprint.plugins.pluginmanager - INFO - Looks like we are offline, can't fetch notices from network
2019-08-23 16:55:48,933 - octoprint.util.pip - INFO - Using "/home/pi/oprint/bin/python2 -m pip" as command to invoke pip
2019-08-23 16:55:48,935 - octoprint.util.pip - INFO - pip installs to /home/pi/oprint/lib/python2.7/site-packages (writable -> yes), --user flag needed -> no, virtual env -> yes
2019-08-23 16:55:48,935 - octoprint.util.pip - INFO - ==> pip ok -> yes
2019-08-23 16:55:50,332 - octoprint.util.pip - INFO - Using "/home/pi/oprint/bin/python2 -m pip" as command to invoke pip
2019-08-23 16:55:54,655 - octoprint.util.pip - INFO - pip installs to /home/pi/oprint/lib/python2.7/site-packages/ (writable -> yes), --user flag needed -> no, virtual env -> yes
2019-08-23 16:55:54,656 - octoprint.util.pip - INFO - ==> pip ok -> yes
2019-08-23 16:55:54,673 - octoprint.plugins.softwareupdate - INFO - Saved version cache to disk
2019-08-23 16:55:54,717 - octoprint.server.preemptive_cache - INFO - Preemptively caching / (ui _default) for {'query_string': 'l10n=de', 'path': '/', 'base_url': 'http://192.168.0.135/'}
2019-08-23 16:56:05,881 - octoprint.server.preemptive_cache - INFO - ... done in 11.16s
2019-08-23 19:58:13,123 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2019-08-23 19:58:13,161 - octoprint.util.connectivity_checker - INFO - Connectivity changed from offline to online
2019-08-23 19:58:13,774 - octoprint.plugins.pluginmanager - INFO - Loaded plugin repository data from https://plugins.octoprint.org/plugins.json
2019-08-23 19:58:14,270 - octoprint.plugins.softwareupdate - INFO - Saved version cache to disk
2019-08-23 19:58:14,540 - octoprint.plugins.pluginmanager - INFO - Loaded plugin notices data from https://plugins.octoprint.org/notices.json
2019-08-23 20:13:13,126 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2019-08-23 20:13:13,648 - octoprint.plugins.tracking - INFO - Sent tracking event ping, payload: {}
2019-08-23 20:17:24,047 - octoprint.server.util.flask - INFO - Passively logging in user Mitschael from ::ffff:192.168.0.129
2019-08-23 20:18:05,220 - octoprint.server - INFO - Shutting down...
2019-08-23 20:18:05,573 - octoprint.events - INFO - Processing shutdown event, this will be our last event
2019-08-23 20:18:05,574 - octoprint.events - INFO - Event loop shut down
2019-08-23 20:18:05,590 - octoprint.server - INFO - Goodbye!
2019-08-23 20:18:13,141 - octoprint.startup - INFO - ******************************************************************************
2019-08-23 20:18:13,143 - octoprint.startup - INFO - Starting OctoPrint 1.3.10
2019-08-23 20:18:13,145 - octoprint.startup - INFO - ******************************************************************************
2019-08-23 20:18:14,315 - octoprint.startup - INFO - We don't appear to be online, not fetching plugin blacklist
2019-08-23 20:18:14,384 - octoprint.plugin.core - INFO - Loading plugins from /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins, /home/pi/.octoprint/plugins and installed plugin packages...
2019-08-23 20:18:16,743 - octoprint.plugin.core - INFO - Found 15 plugin(s) providing 15 mixin implementations, 17 hook handlers
2019-08-23 20:18:16,862 - octoprint.server.heartbeat - INFO - Starting server heartbeat, 900.0s interval
2019-08-23 20:18:16,911 - octoprint.server - INFO - Intermediary server started
2019-08-23 20:18:16,913 - octoprint.plugin.core - INFO - Loading plugins from /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins, /home/pi/.octoprint/plugins and installed plugin packages...
2019-08-23 20:18:17,485 - octoprint.plugin.core - INFO - Found 15 plugin(s) providing 15 mixin implementations, 17 hook handlers
2019-08-23 20:18:17,525 - octoprint.filemanager.storage - INFO - Initializing the file metadata for /home/pi/.octoprint/uploads...
2019-08-23 20:18:17,527 - octoprint.filemanager.storage - INFO - ... file metadata for /home/pi/.octoprint/uploads initialized successfully.
2019-08-23 20:18:17,543 - octoprint.plugins.tracking - INFO - Initialized anonymous tracking
2019-08-23 20:18:17,576 - octoprint.plugins.softwareupdate - INFO - Loaded version cache from disk
2019-08-23 20:18:19,364 - octoprint.util.pip - INFO - Using "/home/pi/oprint/bin/python2 -m pip" as command to invoke pip
2019-08-23 20:18:20,952 - octoprint.util.pip - INFO - Version of pip is 19.0.1
2019-08-23 20:18:20,954 - octoprint.util.pip - INFO - pip installs to /home/pi/oprint/lib/python2.7/site-packages (writable -> yes), --user flag needed -> no, virtual env -> yes
2019-08-23 20:18:20,955 - octoprint.util.pip - INFO - ==> pip ok -> yes
2019-08-23 20:18:20,960 - octoprint.plugin.core - INFO - Initialized 15 plugin implementation(s)
2019-08-23 20:18:20,969 - octoprint.plugin.core - INFO - 15 plugin(s) registered with the system:
2019-08-23 20:18:21,000 - octoprint.environment - INFO - Detected environment is Python 2.7.13 under Linux (linux2). Details:
| hardware:
| cores: 4
| freq: 1400.0
| ram: 918188032
| os:
| platform: linux2
| plugins:
| pi_support:
| python:
| pip: 19.0.1
| version: 2.7.13
2019-08-23 20:18:21,024 - octoprint.server - INFO - Reset webasset folder /home/pi/.octoprint/generated/webassets...
2019-08-23 20:18:21,053 - octoprint.server - INFO - Reset webasset folder /home/pi/.octoprint/generated/.webassets-cache...
2019-08-23 20:18:21,782 - octoprint.server - INFO - Shutting down intermediary server...
2019-08-23 20:18:22,063 - octoprint.server - INFO - Intermediary server shut down
2019-08-23 20:18:22,066 - octoprint.events - INFO - Processing startup event, this is our first event
2019-08-23 20:18:22,068 - octoprint.events - INFO - Adding 0 events to queue that were held back before startup event
2019-08-23 20:18:22,070 - octoprint.filemanager - INFO - Adding backlog items from all storage types to analysis queue...
2019-08-23 20:18:22,076 - octoprint.filemanager - INFO - Added 0 items from storage type "local" to analysis queue
2019-08-23 20:18:22,094 - octoprint.plugins.discovery - INFO - Registered 'OctoPrint instance on octopi' for _http._tcp
2019-08-23 20:18:22,109 - octoprint.plugins.discovery - INFO - Registered 'OctoPrint instance on octopi' for _octoprint._tcp
2019-08-23 20:18:22,124 - octoprint.plugins.discovery - INFO - Registered OctoPrint instance on octopi for SSDP
2019-08-23 20:18:22,139 - octoprint.server - INFO - Listening on http://127.0.0.1:5000
2019-08-23 20:18:22,275 - octoprint.plugins.pluginmanager - INFO - Loaded plugin repository data from disk, was still valid
2019-08-23 20:18:22,812 - octoprint.plugins.pluginmanager - INFO - Loaded notice data from disk, was still valid
2019-08-23 20:18:23,702 - octoprint.util.pip - INFO - Using "/home/pi/oprint/bin/python2 -m pip" as command to invoke pip
2019-08-23 20:18:23,704 - octoprint.util.pip - INFO - pip installs to /home/pi/oprint/lib/python2.7/site-packages (writable -> yes), --user flag needed -> no, virtual env -> yes
2019-08-23 20:18:23,705 - octoprint.util.pip - INFO - ==> pip ok -> yes
2019-08-23 20:18:23,774 - octoprint.util.connectivity_checker - INFO - Connectivity changed from offline to online
2019-08-23 20:18:23,797 - octoprint.plugins.pluginmanager - INFO - Loaded plugin repository data from disk, was still valid
2019-08-23 20:18:24,347 - octoprint.plugins.pluginmanager - INFO - Loaded notice data from disk, was still valid
2019-08-23 20:18:24,593 - octoprint.plugins.tracking - INFO - Sent tracking event startup, payload: {'python': '2.7.13', 'ram': 918188032, 'octopi_version': '0.16.0', 'version': u'1.3.10', 'pip': '19.0.1', 'cores': 4, 'freq': 1400.0, 'p$
2019-08-23 20:18:34,876 - octoprint.server.preemptive_cache - INFO - ... done in 10.53s
2019-08-23 20:20:17,213 - octoprint.server - INFO - Shutting down...
2019-08-23 20:20:17,900 - octoprint.events - INFO - Processing shutdown event, this will be our last event
2019-08-23 20:20:17,903 - octoprint.events - INFO - Event loop shut down
2019-08-23 20:20:17,922 - octoprint.server - INFO - Goodbye!
2019-08-23 20:20:25,166 - octoprint.startup - INFO - ******************************************************************************
2019-08-23 20:20:25,168 - octoprint.startup - INFO - Starting OctoPrint 1.3.10
2019-08-23 20:20:25,169 - octoprint.startup - INFO - ******************************************************************************
2019-08-23 20:20:26,568 - octoprint.startup - INFO - We don't appear to be online, not fetching plugin blacklist
2019-08-23 20:20:26,638 - octoprint.plugin.core - INFO - Loading plugins from /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins, /home/pi/.octoprint/plugins and installed plugin packages...
2019-08-23 20:20:29,047 - octoprint.plugin.core - INFO - Found 15 plugin(s) providing 15 mixin implementations, 17 hook handlers
2019-08-23 20:20:29,212 - octoprint.server.heartbeat - INFO - Starting server heartbeat, 900.0s interval
2019-08-23 20:20:29,265 - octoprint.server - INFO - Intermediary server started
2019-08-23 20:20:29,266 - octoprint.plugin.core - INFO - Loading plugins from /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins, /home/pi/.octoprint/plugins and installed plugin packages...
2019-08-23 20:20:29,785 - octoprint.plugin.core - INFO - Found 15 plugin(s) providing 15 mixin implementations, 17 hook handlers
2019-08-23 20:20:29,821 - octoprint.filemanager.storage - INFO - Initializing the file metadata for /home/pi/.octoprint/uploads...
2019-08-23 20:20:29,822 - octoprint.filemanager.storage - INFO - ... file metadata for /home/pi/.octoprint/uploads initialized successfully.
2019-08-23 20:20:29,839 - octoprint.plugins.tracking - INFO - Initialized anonymous tracking
2019-08-23 20:20:29,872 - octoprint.plugins.softwareupdate - INFO - Loaded version cache from disk
2019-08-23 20:20:31,664 - octoprint.util.pip - INFO - Using "/home/pi/oprint/bin/python2 -m pip" as command to invoke pip
2019-08-23 20:20:33,258 - octoprint.util.pip - INFO - Version of pip is 19.0.1
2019-08-23 20:20:33,260 - octoprint.util.pip - INFO - pip installs to /home/pi/oprint/lib/python2.7/site-packages (writable -> yes), --user flag needed -> no, virtual env -> yes
2019-08-23 20:20:33,261 - octoprint.util.pip - INFO - ==> pip ok -> yes
2019-08-23 20:20:33,267 - octoprint.plugin.core - INFO - Initialized 15 plugin implementation(s)
2019-08-23 20:20:33,278 - octoprint.plugin.core - INFO - 15 plugin(s) registered with the system:
2019-08-23 20:20:33,300 - octoprint.environment - INFO - Detected environment is Python 2.7.13 under Linux (linux2). Details:
| hardware:
| cores: 4
| freq: 1400.0
| ram: 918188032
| os:
| platform: linux2
| plugins:
| pi_support:
| python:
| pip: 19.0.1
| version: 2.7.13
2019-08-23 20:20:33,318 - octoprint.server - INFO - Reset webasset folder /home/pi/.octoprint/generated/webassets...
2019-08-23 20:20:33,345 - octoprint.server - INFO - Reset webasset folder /home/pi/.octoprint/generated/.webassets-cache...
2019-08-23 20:20:33,911 - octoprint.server - INFO - Shutting down intermediary server...
2019-08-23 20:20:34,308 - octoprint.server - INFO - Intermediary server shut down
2019-08-23 20:20:34,313 - octoprint.events - INFO - Processing startup event, this is our first event
2019-08-23 20:20:34,314 - octoprint.events - INFO - Adding 0 events to queue that were held back before startup event
2019-08-23 20:20:34,320 - octoprint.filemanager - INFO - Adding backlog items from all storage types to analysis queue...
2019-08-23 20:20:34,330 - octoprint.filemanager - INFO - Added 0 items from storage type "local" to analysis queue
2019-08-23 20:20:34,366 - octoprint.plugins.discovery - INFO - Registered 'OctoPrint instance on octopi' for _http._tcp
2019-08-23 20:20:34,394 - octoprint.plugins.discovery - INFO - Registered 'OctoPrint instance on octopi' for _octoprint._tcp
2019-08-23 20:20:34,405 - octoprint.plugins.discovery - INFO - Registered OctoPrint instance on octopi for SSDP
2019-08-23 20:20:34,423 - octoprint.server - INFO - Listening on http://127.0.0.1:5000
2019-08-23 20:20:34,464 - octoprint.plugins.pluginmanager - INFO - Loaded plugin repository data from disk, was still valid
2019-08-23 20:20:35,055 - octoprint.plugins.pluginmanager - INFO - Loaded notice data from disk, was still valid
2019-08-23 20:20:35,928 - octoprint.util.pip - INFO - Using "/home/pi/oprint/bi$
2019-08-23 20:20:35,930 - octoprint.util.pip - INFO - pip installs to /home/pi/$
2019-08-23 20:20:35,931 - octoprint.util.pip - INFO - ==> pip ok -> yes
2019-08-23 20:20:36,023 - octoprint.util.connectivity_checker - INFO - Connecti$
2019-08-23 20:20:36,047 - octoprint.plugins.pluginmanager - INFO - Loaded plugi$
2019-08-23 20:20:36,440 - octoprint.plugins.pluginmanager - INFO - Loaded notic$
2019-08-23 20:20:36,587 - octoprint.server.preemptive_cache - INFO - Preemptive$
2019-08-23 20:20:36,984 - octoprint.plugins.tracking - INFO - Sent tracking eve$
2019-08-23 20:20:47,317 - octoprint.server.preemptive_cache - INFO - ... done i$
2019-08-23 20:21:47,556 - octoprint.server - INFO - Shutting down...
2019-08-23 20:21:47,737 - octoprint.events - INFO - Processing shutdown event, $
2019-08-23 20:21:47,738 - octoprint.events - INFO - Event loop shut down
2019-08-23 20:21:47,753 - octoprint.server - INFO - Goodbye!
I also tried to put it on another port (e.g. 5001) but same here.
This is my haproxy.cfg file (got it from here (I tried the default before but no difference)):
global
maxconn 4096
user haproxy
group haproxy
tune.ssl.default-dh-param 1024
log 127.0.0.1 local1 debug
defaults
log global
mode http
option httplog
option dontlognull
retries 3
option redispatch
option http-server-close
option forwardfor
maxconn 2000
timeout connect 5s
timeout client 15min
timeout server 15min
frontend public
bind *:81
default_backend octoprint
errorfile 503 /etc/haproxy/errors/503-no-octoprint.http
frontend internet
bind 0.0.0.0:444 ssl crt /etc/ssl/snakeoil.pem
acl Authorization http_auth(inetusers)
http-request auth realm octoprint if !Authorization
frontend webcamonly
bind *:9080
default_backend webcamstream
backend octoprint
reqrep ^([^\ :]*)\ /(.*) \1\ /\2
reqadd X-Scheme:\ https if { ssl_fc }
option forwardfor
backend webcam
reqrep ^([^\ :]*)\ /webcam/(.*) \1\ /\2
server webcam1 127.0.0.1:8080
reqrep ^([^\ :]*)\ /(.*) \1\ /\?action=stream
userlist inetusers
group G1
user [user] insecure-password [password] groups G1
(And I obviously tried to restart octoprint and reboot the pi too.)
I'm sorry for pasting in so much code but I wanted to make sure that there isn't missing a thing.
After searching through the forum, I found that after this "~/oprint/bin/octoprint serve" I get this: 2019-08-24 11:30:43,247 - octoprint.startup - CRITICAL - Could not initialize settings manager: Folder at /home/pi/.octoprint/scripts doesn't appear to be writable, please fix its permissions 2019-08-24 11:30:43,247 - octoprint.startup - CRITICAL - There was a fatal error starting up OctoPrint. Could not initialize settings manager: Folder at /home/pi/.octoprint/scripts doesn't appear to be writable, please fix its permissions There was a fatal error starting up OctoPrint.
After giving permission (sudo chmod a+w path_to_the_file) I got this:
octoprint.startup - CRITICAL - Could not initialize lo gging: Unable to configure handler 'file': [Errno 13] Permission denied: '/home/ pi/.octoprint/logs/octoprint.log' octoprint.startup - CRITICAL - There was a fatal error starting up OctoPrint. Could not initialize logging: Unable to configure handler 'file': [Errno 13] Per mission denied: '/home/pi/.octoprint/logs/octoprint.log' There was a fatal error starting up OctoPrint
Thanks in advance!
