octoprint.log (21.3 KB)<a
I did not make any changes or updates, I wanted to sign up and found that it did not work
https://octoprint.juricekpavel.net/
after restarting to safe mode already works resolved thank you
accessControl:
appearance:
defaultLanguage: cs
feature:
legacyPluginAssets: true
plugins:
announcements:
_config_version: 1
channels:
_blog:
read_until: 1529054100
_important:
read_until: 1521111600
_octopi:
read_until: 1527588900
_plugins:
read_until: 1529280000
_releases:
read_until: 1529502000
cura:
cura_engine: /usr/bin/CuraEngine
debug_logging: true
discovery:
upnpUuid: e14058fd-fa14-454e-a3bb-4d49b2dfaf05
multicam:
_config_version: 1
multicam_profiles:
- URL: https://octoprint.juricekpavel.net/w-otoc.cgi
isButtonEnabled: false
- URL: https://octoprint.juricekpavel.net/w-a1.cgi
isButtonEnabled: true
- URL: https://octoprint.juricekpavel.net/w-a2.cgi
pluginmanager:
pip_force_user: true
softwareupdate:
_config_version: 6
check_providers:
cost: cost
multicam: multicam
navbartemp: navbartemp
printerProfiles:
default: _default
serial:
autoconnect: true
baudrate: 115200
server:
commands:
serverRestartCommand: sudo service octoprint restart
systemRestartCommand: sudo shutdown -r now
systemShutdownCommand: sudo shutdown -h now
firstRun: false
onlineCheck:
enabled: true
pluginBlacklist:
enabled: true
seenWizards:
corewizard: 3
cura: null
temperature:
profiles:
- bed: 100
extruder: 210
- bed: 60
extruder: 180
- bed: '75'
extruder: '220'
system:
actions:
- action: pon
command: printer_on.sh
- action: poff
command: printer_off.sh
confirm: Opravdu chcete tiskarnu vypnout?
- action: lon
command: light_on.sh
- action: loff
command: light_off.sh
event: PrintDone
- action: l1on
command: light1_on.sh
- action: loff
command: light1_off.sh
event: PrintDone
- action: vent
command: vent_on.sh
confirm: Opravdu chcete ventilator zapnout?
- action: loff
command: vent_off.sh
confirm: Opravdu chcete ventilator vypnout?
event: PrintDone
webcam:
stream: https://octoprint.juricekpavel.net/w-otoc.cgi
! $ root@3dtisk ~ service octoprint status
● octoprint.service - OctoPrint
Loaded: loaded (/etc/systemd/system/octoprint.service; enabled; vendor preset
Active: failed (Result: exit-code) since Sat 2018-07-07 00:36:19 CEST; 25s ag
Process: 1791 ExecStart=/home/octoprint/OctoPrint/venv/bin/octoprint serve --h
Main PID: 1791 (code=exited, status=1/FAILURE)
čec 07 00:36:19 3dtisk systemd[1]: octoprint.service: Service hold-off time over
čec 07 00:36:19 3dtisk systemd[1]: octoprint.service: Scheduled restart job, res
čec 07 00:36:19 3dtisk systemd[1]: Stopped OctoPrint.
čec 07 00:36:19 3dtisk systemd[1]: octoprint.service: Start request repeated too
čec 07 00:36:19 3dtisk systemd[1]: octoprint.service: Failed with result 'exit-c
čec 07 00:36:19 3dtisk systemd[1]: Failed to start OctoPrint.
lines 1-12/12 (END)⏎
