Since I first started to use OctoPrint (which was just a few months ago) I have the issue that whatever settings I change keep disappearing after I reboot the Pi. With "settings" I am talking about the timelapse settings as well as the g-code scripts. Changes on the printer profile seem to work.
I am using OctoPrint on a Raspberry Pi 3B+ from fresh OctoPi-Installations. Happened at 0.16.0 to 0.17.0. I tried reflashing several times with different versions and tried 2 different SD cards.
I change nothing from the vanilla OctoPi except edit the wpa file for my wifi and setup my printer with the default dialog. I do not use any strange characters in my printer profile name. Even though I change the pi username, I also tried to leave it as default "raspberry". Nothing helps.
I may note: Everything else on the Pi and OctoPrint works fine! I can update it, I can upload files and print, it just looses all normal settings after reboot. Uploaded files, the printer profile and even some test files I create over ssh on the pi stay where they are.
This log is from a complete fresh install, here I tried to save at least 2 times which both did not work.
I include the octoprint.log, if there is any other file you might need, just say so.
octoprint.log (26.6 KB)
I am browsing OcotoPrint using Safari on a Mac but also tried to use Firefox and even Chrome. I am completely clueless on this issue as it looks like there is nothing special in my case so this should affect everyone or no-one? If you have any idea on what might be the issue, feel free to share it.
