Slicer
Name, version, operating system
PrusaSlicer 2.7.4
Anytime I send a print from Octoprint, the print immediately starts without the proper bed/nozzle temp. The target temps listed on the dashboard are at 0°C. When I transfer the same g-code to the SD card and printer from there, everything works like it should.
When I manually preheat the bed/nozzle from the printer and then submit the job from Octoprint, I notice that it does not extrude any filament.
upgraded OctoPrint, PrusaSlicer, Printer Firmware and also removed and added the printer in OctoPrint.
octoprint-systeminfo-20240724120204.zip (57.4 KB)
Example GCODE file
Please upload here, the forum supports file uploads of GCODE files
CABLE CLIP_0.15mm_PLA_MK3S_7m.gcode (275.4 KB)
I will post the terminal commands from this print job shortly
OctoPrint Version: 1.10.2
Printer: Prusa MK3S+
Firmware: 3.14.0
