Octoprint wont run
I tried to install the desktop for octopi using the command in the terminal. It appeared to of completed normally and asked for a reboot. After rebooting I get the octoprint server not running screen in my browser, and in the terminal it still has the text mentioning that the desktop is available to install.
Restart server commands
check logs for obvious errors
rerun the desktop environment install script
rebooting the pi, including shutting down then power cycle
Search forms for issues similar to this
partial copy of my terminal
pi@octopiMK3S:~ $ ps -ef | grep -i octoprint
pi 690 605 0 22:38 pts/0 00:00:00 grep --color=auto -i octoprint
pi@octopiMK3S:~ $ sudo service octoprint restart
pi 723 605 0 22:39 pts/0 00:00:00 grep --color=auto -i octoprint
pi@octopiMK3S:~ $ ps -ef | grep -i octoprint | grep -i python
pi@octopiMK3S:~ $ tail ~/.octoprint/logs/octoprint.log
2019-05-30 21:24:35,891 - octoprint.plugins.navbartemp - INFO - Checking SoC internal temperature
2019-05-30 21:25:05,948 - octoprint.plugins.navbartemp - INFO - Checking SoC internal temperature
2019-05-30 21:25:36,003 - octoprint.plugins.navbartemp - INFO - Checking SoC internal temperature
2019-05-30 21:26:06,058 - octoprint.plugins.navbartemp - INFO - Checking SoC internal temperature
2019-05-30 21:26:36,113 - octoprint.plugins.navbartemp - INFO - Checking SoC internal temperature
2019-05-30 21:26:54,472 - octoprint.server.util.sockjs - INFO - Client connection closed: ::ffff:192.168.1.141
2019-05-30 21:26:56,009 - octoprint.server - INFO - Shutting down...
2019-05-30 21:26:56,965 - octoprint.events - INFO - Processing shutdown event, this will be our last event
2019-05-30 21:26:56,967 - octoprint.events - INFO - Event loop shut down
2019-05-30 21:26:56,988 - octoprint.server - INFO - Goodbye!
pi@octopiMK3S:~ $
the last line of the log is 1-2hrs old, so the log hasnt been written to since the initial shutdown from trying to install the desktop environment.
Link to syslog
