OctoPrint not using the Z Offset
### What is the problem?
Any prints that are started from OctoPrint are not using the Z Offset.
### What did you already try to solve it?
I searched online for solutions as to why OctoPrint was not using the offset and there were a lot of reasons, but none made sense for my case.
### Additional information about your setup
Ender 3 Pro with v 1.1.15 silent board
Installed BL Touch according to Creality, I flashed the firmware that they said to ( (2019.11.13)Ender-3 Pro1.1.6BLTouchV3.1PowerLossContinueEnglish.hex) and preformed the platform adjustment, setting the Z Offset.
I am using a very vanilla install of OctoPrint, and from what I read OctoPrint is supposed to use the Z Offset value which is saved in the EEPROM.
I installed the EEPROM Editor plugin and from there I can see the correct value.
I took 3 different print gcode's that would not print properly in OctoPrint and copied them to the sd card. They printed simply fine from the sd card. So, at this point I am not sure where the issue is, there are so many different things about this issue that I'm not sure what is the correct thing to try.
OctoPrint Version: 1.5.3
OctoPi Version: 0.17.0, running on Raspberry Pi 2 Model B Rev 1.1
System Information:
connectivity.connection_check: 8.8.8.8:53
connectivity.enabled: true
connectivity.online: true
env.hardware.cores: 4
env.hardware.freq: 900
env.hardware.ram: 915726336
env.os.bits: 32
env.os.id: linux
env.os.platform: linux2
env.plugins.pi_support.model: Raspberry Pi 2 Model B Rev 1.1
env.plugins.pi_support.octopi_version: 0.17.0
env.python.pip: 19.3.1
env.python.version: 2.7.16
env.python.virtualenv: true
octoprint.safe_mode: false
octoprint.version: 1.5.3
printer.firmware: Marlin Creality 3D
Thanks,
Matt
Hello @Mroell!
Have you seen this:
and this:
from here:
https://community.octoprint.org/search?q=z-offset
I read through it all and spent a few hours trying different firmware, https://www.danbp.org/p/en/node/136 I was trying to install 1.1.9.1+ Bugfix + BLTouch for Ender 3 (Aug 3rd, 2020) which is the recommended firmware. I couldn't get it to install. So in the end I'm still using the firmware that came with. I reset up the z offset and it's doing the same thing.
I may well be wrong but a quick look at the page you referenced suggests that the firmware he's compiled is for Ender3 whereas you said you had an EnderPro with a silent board, are the compatible?
I'm surprised that OctoPrint would use the Z value, surely it just send the GCode you specify and the printer adds or subtracts the Z value to any Z move.
BTW I suggest you read the comments.
Hi Towlerg,
In the comments (There are a few hundred comments) on that page people have flashed it with board v 1.1.15 (silent board). On Ender's website they list that the firmware is for Ender-3(Pro)/Ender-5(pro)/CR-10/Ender 3v2 but regardless of that OctoPrint should just send the GCode like your saying to the printer and it does everything else and that's where it I'm at a loss as to why it's not doing that.
So I'm not sure what was going on here, but I'm back to using the firmware from Creality and I reloaded Octopi for a different reason and so far after two prints it's working as expected.
Ok - so there seem to be many different issues...
If you power on your printer without the last SD card you used inserted - Is the Z offset reported as 0 or the value it was previously set to? If it is 0 and you then insert the SD card, does it suddenly change to the previously set value?
If you are able to power on the printer without the SD card inserted and the previous Z offset value is displayed, then the firmware you are using is storing the Z offset in the mainboard EEPROM.
If you see 0 but then see the previous value after inserting the SD card then the firmware is storing and retrieving the Z offset from a file on the SD card called EEPROM.dat.
With regard to the EEPROM editor plugin, My Ender 3 v2 reports firmware version 1.1.2 under info on the display panel. I installed the 1.1.2 firmware which is meant to have Marlin firmware 2.0.1 for BL/CR touch which I downloaded from creality.com - the firmware was dated 26 March 2021. The EEPROM editor plugin reports Marlin firmware v1.1.1 - I don't know why the EEPROM editor plugin reports the wrong version but it doesn't matter much since it's unable to Save the configuration without the SD card.
I tried sending M500 via the terminal but I got a "No EEPROM" reply.
I'm beginning to think that either there is no actual EEPROM on the mainboard or if there is an EEPROM then maybe it's too small to store all of the settings needed for Marlin 2.0.1 firmware.
Anyway, I think the only solution to the "OctoPrint not using the Z Offset" problem is to keep an SD card inserted so that the Z offset parameter can be stored in (and read back from) the EEPROM.dat file.
octoprint-systeminfo-20211002192003.zip (11.3 KB)
Creality, in their firmware, disabled using the onboard EEPROM for a lot of printers and save it to the SD card instead, who knows why. You can't mix and match here, if it is set in the firmware to use the SD card, it must do that, or it is set to use the onboard chip. Most of their boards do have actual onboard EEPROM they disabled...
Considering the number of bugs we see with Creality's firmware it's highly recommended to build your own or use some other source of firmware - but thanks for sharing one of the very likely causes of this issue.
It just reports what it is told by the printer, using the M115 command data. Creality (once again messing with things) changed the version numbers in their firmware so what was Marlin 2.0.x became Creality-Marlin 1.x...
I'm struggling with the same issue. I connected my Pi4 with octoprint to my standard ender 5 S1. When the printing starts it raises the bed till the nozzle and keeps going. What to do?
