I've downloaded, flashed the .img file. Found the IP address (does nothing) Rebooted my Pi3B+ located the "Boot" icon changed the SSID and password box, removed the #s making the lines active.
Rebooted the Pi, little blue light flashes on the SD adapter. Typed in "https://octopi.local" (Nothing happens except a message telling me it cannot be found) Types in "https://"my pi's ip" (Nothing same message as above)
I've tried reinstalling several times same messages each time. Searched my router for the Pi it's found it's mac address. My network is not showing my Pi
I assume you put the SD adapter into one of the USB ports of the PI.
You may try again with inserting the SD card into the SD card slot on the bottom side of the Pi.
This is the part ive added my internet details too. If I put my routers IP into a search engine it shows that Octopi.local and my pi are present, however, nothing happens
This is my pi complete with the micro sd holding the operating system. The white holder has a blue led when it’s powered and reading or writing the SD Card is on the other side. I tried to upload two pictures, unfortunately the system won't permit it
One blue led. The system is reading what's on the SD Chip, that's as far as it gets! I can get into sudo raspi-config etc
cannot find http://octopi.local or https://octopi.local either
