Everytime I load into my octoprint interface on my browser I can connect just fine to the printer I can see the webcam interface no problems, but when i try to do anything, change the temperature, move the ectruder or start a print I just get the red box error on the right hand side of the browser whicg says.
" Communication error
There was a communication error while talking to your printer. Please consult the terminal output and octoprint.log for details. Error: Too many consecutive timeouts, printer still connected and alive?"
I tried a complete reinstall multiple times, I have tried using an ethernet instead of wifi and tried a new power cable, i currently am using a 5V 3A micro usb charger with on and off power switch which states on amazon it is dor rassberry pu models B+ which is the model I have
Logs
Serial port list: ['/dev/ttyUSB0']
Connecting to: /dev/ttyUSB0
Connected to: Serial<id=0x763435d0, open=True>(port='/dev/ttyUSB0', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=10.0, xonxoff=False, rtscts=False, dsrdtr=False), starting monitor
Starting baud rate detection...
Trying baudrate: 115200
Recv: Test my message
Send: N0 M110 N0*125
Recv: echo: External Reset
Recv: 1.0.0
Recv: echo:(none, default config)
Recv: Dec 27 2018
Recv: echo:10075echo:Hardcoded Default Settings Loaded
Recv: echo:Steps per unit:
Recv: echo: M92 X80.00 Y80.00 Z400.00 E93.00echo:Maximum feedrates (mm/s):
Recv: echo: M203 X500.00 Y500.00 Z5.00 E25.00echo:Maximum Acceleration (mm/s2):
Recv: echo: M201 X500 Y500 Z100 E5000echo:Acceleration: S=acceleration, T=retract acceleration
Recv: echo: M204 S500.00 T500.00echo:Advanced variables: S=Min feedrate (mm/s), T=Min travel feedrate (mm/s), B=minimum segment time (ms), X=maximum XY jerk (mm/s), Z=maximum Z jerk (mm/s), E=maximum E jerk (mm/s)
Recv: echo: M205 S0.00 T0.00 B20000 X20.00 Z0.40 E5.00echo:Home offset (mm):
Recv: echo: M206 X0.00 Y0.00 Z0.00echo:PID settings:
Recv: echo: M301 P21.73 I1.54 D76.55echo:SD init fail
Recv: echo:SD init fail
Recv: ok
Changing monitoring state from "Detecting baudrate" to "Operational"
Recv: ok
Send: N1 M115*39
Recv: FIRMWARE_NAME:Marlin V1; Sprinter/grbl mashup for gen6 FIRMWARE_URL:http://www.mendel-parts.com PROTOCOL_VERSION:1.0 MACHINE_TYPE:CTC 3D EXTRUDER_COUNT:1 UUID:00000000-0000-0000-0000-000000000000
Recv: ok
Send: M21
Recv: ok
Changing monitoring state from "Operational" to "Starting"
Recv: ok
Changing monitoring state from "Starting" to "Printing"
Send: N1 M190 S45*88
Recv: T:17.46 E:0 B:17.7T:17.50 E:0 B:18.1T:17.42 E:0 B:18.1T:17.50 E:0 B:18.7T:17.50 E:0 B:19.4T:17.46 E:0 B:20.0T:17.42 E:0 B:20.6T:17.50 E:0 B:21.8T:17.50 E:0 B:22.5T:17.46 E:0 B:23.1T:17.46 E:0 B:24.4T:17.50 E:0 B:25.0T:17.42 E:0 B:25.5T:17.50 E:0 B:26.4T:17.50 E:0 B:26.8T:17.50 E:0 B:27.5T:17.50 E:0 B:28.2T:17.50 E:0 B:28.9T:17.46 E:0 B:29.5T:17.46 E:0 B:30.0T:17.50 E:0 B:30.8T:17.46 E:0 B:31.2T:17.50 E:0 B:32.1T:17.50 E:0 B:32.5T:17.50 E:0 B:33.3T:17.46 E:0 B:33.7T:17.50 E:0 B:34.6T:17.46 E:0 B:35.1T:17.50 E:0 B:35.7T:17.50 E:0 B:36.2T:17.50 E:0 B:36.7T:17.50 E:0 B:37.2T:17.46 E:0 B:37.7T:17.50 E:0 B:38.3T:17.50 E:0 B:38.7T:17.50 E:0 B:39.3T:17.50 E:0 B:39.7T:17.50 E:0 B:40.3T:17.50 E:0 B:40.6T:17.46 E:0 B:41.2T:17.46 E:0 B:41.8T:17.50 E:0 B:42.1T:17.50 E:0 B:42.6T:17.46 E:0 B:42.9T:17.50 E:0 B:43.5T:17.50 E:0 B:43.8T:17.42 E:0 B:44.4T:17.46 E:0 B:44.7ok
No response from printer after 6 consecutive communication timeouts, considering it dead. Configure long running commands or increase communication timeout if that happens regularly on specific commands or long moves.
Changing monitoring state from "Printing" to "Offline (Error: Too many consecutive timeouts, printer still connected and alive?)"
PI Model B+
Ender 3 Mostly stock
