So on boot up there are a lot of FAILED Error Messages and nothing happens
3 Time re Installing OctoPi on my Zero 2
But it didnt change anything
Image with Errors:
Image with Errors:
Have you tried a different SD card? It's showing a lot of file system errors, which could be related to the SD card itself not working properly.
Yeah i tried that. Is it possible that the power supply is the Problem?
I use a charger with 5V 2A
I doubt this is a PS issue. It looks like, other than the boot files themselves, nothing is accessible on the SD card. How did you flash it?
If you already tried it with a second sd card then you may want to change other elements of the procedure to find where the error occurs. Download the image again. Use a different program for flashing the image. Try it on another computer. etc
If you are really using a "charger" instead of a "power supply" then that could (or will likely) cause problems. The internal circuitry of a "charger" is different and not appropriate for use as a "power supply".
