Octoprint/OctoPi : space issues
Not really a "problem", per se. More like proactive maintenance.
Space on OctoPi was filling up. What I would like to know, RE: OCTOPI . ... there is a directory on the Pi labelled /docs Is that just user documentation, and would it be safe to delete? I gained about 475Mb of space cleaning of extra stuff yesterday, and noticed when I ran >>sudo ncdu that there was a lot of space taken up in the /docs folder. If I don't need that, I would just delete it...
The other thing I don't quite understand is why I'm bumping into space limits on a 64Gb SD card. It looks like only a couple Gb are being used. Maybe that's a different question, but maybe there's a way to modify the partition on the SD card to have more use of the free space? I don't keep stuff on the Pi at all. Once I'm done with it (gcode, stills, etc) it gets moved off.
Thanks,
S~
Investigate and delete filed
Not applicable, but yes.
No.
Not at home at the moment to provide bundle
1.8.7 (just updated last night)
Ender 5S, V1.1.6.7
R-Pi 3B w/ 64gb SD card
Try sudo ncdu /
That shows you the usage of the whole partition
Yes, thanks I did that, I was typing from memory. My Linux is pretty rusty, not sure if there is a way to extend or increase the size of the partition....
Usually that's done on first boot in the background
What does df -h output?
I'll have to get back to you on that one - I'm at work. I do recall it shows a partition size of 2.4Gb, and my initial issue was that I only had <100Mb available. I've go that up to ~500Mb or so, which is usable, but I have way more space on the card available....
If your partition size wasn't showing the full available space of the SD card you probably need to use raspi-config to extend the filesystem.
Exactly. This is just what I was looking for thanks.
Just wanted to follow up on this. Ran sudo raspi-config and expanded the file system... 58.3Gb total, 54Gb available. I don't think I'm gonna hit a limit any time soon... Thanks :+1: :+1:
