After loading a gcode file to OctoPrint local (not on SD card), sometimes the information will load into the G-Code viewer, and sometimes it won't
Clicking the 'reload' and 'reset' buttons near the bottom of the page;
Restarting Octoprint sometimes enables it.
No... n/a?
OctoPrint installed on a Dell i5 system running Win10 22H2,
Connected by USB direct to Ender 3 S1 printer.
Connecting using Firefox current version.
What must happen in order to load the file into the G-Code viewer?
There is a known issue with large gcode files that should be fixed in version 122 of Firefox.
opened 01:57AM - 29 Aug 23 UTC
bug
not octoprint
### The problem
Large gcode files (> ~15 MB) loaded into OctoPrint will "parse"β¦ to a given number (depending on the gcode; it seems to be consistent per file, but varies between files) and then stop. I can't find any errors in the console either. Smaller gcode files, however, work properly.
It seems to work in Chrome, but I do not use Chrome. I confirmed by turning off content blockers and using an effectively vanilla installation of Firefox (it had uBlock Origin installed, but I disabled that before testing) that it's not just a configuration issue with my local Firefox installation.
### Did the issue persist even in safe mode?
Yes, it did persist
### If you could not test in safe mode, please state why ("currently printing" is NOT an excuse!)
_No response_
### Version of OctoPrint
1.9.2
### Operating system running OctoPrint
Linux (Ubuntu 24.04)
### Printer model & used firmware incl. version
N/A
### Browser and version of browser, operating system running browser
Firefox 116.0 (persists across multiple OSes)
### Checklist of files to include below
- [X] Systeminfo Bundle (always include!)
- [X] Contents of the JavaScript browser console (always include in cases of issues with the user interface)
- [X] Screenshots and/or videos showing the problem (always include in case of issues with the user interface)
- [X] GCODE file with which to reproduce (always include in case of issues with GCODE analysis or printing behaviour)
### Additional information & file uploads
[octoprint-systeminfo-20230828002951.zip](https://github.com/OctoPrint/OctoPrint/files/12449163/octoprint-systeminfo-20230828002951.zip)
[console-export-2023-8-28_18-9-56.txt](https://github.com/OctoPrint/OctoPrint/files/12459233/console-export-2023-8-28_18-9-56.txt)
https://github.com/OctoPrint/OctoPrint/assets/605502/7c531928-ee16-459e-b43e-430cc3a160c1
[gcode that triggers issue (gunzip before using)](https://github.com/OctoPrint/OctoPrint/files/12459264/Gear.fidget.all.holes_0.1mm_Generic-PLA_SV04.gcode.gz)
It happens with a 25K file.... is that too large?
No, that's tiny in comparison to the files that were giving issues. Maybe you have UI Customizer installed as well? I've seen some posts back and forth about some weirdness there with it's widget as well.
Yeah, the only solution I've found is to restart the program, which takes a while.
I also notice that the "reset view" and "Reload" don't seem to do anything.
Not that it will keep me from using the program, but it is an annoyance.
system
Closed
February 27, 2024, 5:21pm
6
