I wanted to update OctoPrint to 1.8.6 on my old system which was CentOS 7 but it lacked a modern enough Python version, and compiling Python source didn't work. I changed my OS to Lubuntu which could install up-to-date OctoPrint; however, I can no longer connect to my printer. The exact same hardware (control board, USB cable, power supply, etc.) never had a problem with my old setup.
The OctoPrint terminal hangs on the status, "Connecting to port /dev/ttyUSB0, baudrate 115200", which I've confirmed are the correct port and baud. Putty is able to connect to the control board from my OctoPrint server and receives replies to commands.
All I've tried has only been able to narrow down the problem, such as using Putty to communicate with the control board. Nothing I've found googling has helped resolve this problem or explain why it's happening.
Yes
octoprint.log (206.4 KB)
OctoPrint 1.8.6
Python 3.10.6
CR-10, Control board v4.2.7
TH3D Unified 2.0 firmware (sub-version unknown)
Chrome v109.0.5414.120
Ubuntu 22.04.1 LTS
Linux 5.15.0-58-generic
