The pip command could not be found or does not work correctly for this installation of OctoPrint - please consult the log file for details and if necessary configure it manually. No installation and uninstallation of plugin packages is possible while pip is unavailable.
I have Ubuntu running in a virtual box with a few of my other servers (bad idea I know but I have snapshots/backups in case something go's south). I have the service running and up so I can access it and it was communicating with my printer / printing something earlier but was very slow then later when I tried to play with Octoprint again it wouldn't communicate with it anymore?
Reinstalling Python / Pip and googling the error. I also attempted to correct the read problem with sudo chmod 775 OctoPrint and on .octoprint as well.
Checking comm settings will restart the server when I get home to see if this fix's the comm issue..
2020-01-01 01:04:18,969 - octoprint.environment - INFO - Detected environment is Python 2.7.17 under Linux (linux2). Details:
| hardware:
| cores: 4
| freq: 0.0
| ram: 12591849472
| os:
| platform: linux2
| python:
| pip: 19.3.1
| version: 2.7.17
| virtualenv: /home/stealth95l/OctoPrint/venv
2020-01-01 01:04:18,971 - octoprint.server - INFO - Reset webasset folder /home/pi/.octoprint/generated/webassets...
2020-01-01 01:04:18,974 - octoprint.server - INFO - Reset webasset folder /home/pi/.octoprint/generated/.webassets-cache...
2020-01-01 01:04:19,138 - octoprint.server - INFO - Shutting down intermediary server...
2020-01-01 01:04:19,508 - octoprint.server - INFO - Intermediary server shut down
2020-01-01 01:04:19,508 - octoprint.events - INFO - Processing startup event, this is our first event
2020-01-01 01:04:19,509 - octoprint.events - INFO - Adding 1 events to queue that were held back before startup event
2020-01-01 01:04:19,509 - octoprint.filemanager - INFO - Adding backlog items from all storage types to analysis queue...
2020-01-01 01:04:19,511 - octoprint.filemanager - INFO - Added 0 items from storage type "local" to analysis queue
2020-01-01 01:04:19,514 - octoprint.plugins.pluginmanager - INFO - Loaded plugin repository data from disk, was still valid
2020-01-01 01:04:19,621 - octoprint.server.util.watchdog - INFO - Running initial scan on watched folder...
2020-01-01 01:04:19,631 - octoprint.server.util.watchdog - INFO - ... initial scan done.
2020-01-01 01:04:19,679 - octoprint.server - INFO - Listening on http://0.0.0.0:5000 and http://[::]:5000
2020-01-01 01:04:19,682 - octoprint.plugins.discovery - INFO - Registered OctoPrint instance on aviushub for SSDP
2020-01-01 01:04:19,701 - octoprint.plugins.pluginmanager - INFO - Loaded plugin repository data from disk, was still valid
2020-01-01 01:04:19,826 - octoprint.plugins.pluginmanager - INFO - Loaded notice data from disk, was still valid
2020-01-01 01:04:19,886 - octoprint.plugins.pluginmanager - INFO - Loaded notice data from disk, was still valid
2020-01-01 01:04:19,925 - octoprint.util.pip - INFO - Using "/home/stealth95l/OctoPrint/venv/bin/python2 -m pip" as command to invoke pip
2020-01-01 01:04:19,925 - octoprint.util.pip - INFO - pip installs to /home/stealth95l/OctoPrint/venv/lib/python2.7/site-packages (writable -> no), --user flag needed -> no, virtual env -> yes
2020-01-01 01:04:19,925 - octoprint.util.pip - INFO - ==> pip ok -> NO!
2020-01-01 01:04:19,926 - octoprint.util.pip - ERROR - Cannot use this pip install, can't write to the install dir and also can't use --user for installing. Check your setup and the permissions on /home/stealth95l/OctoPrint/venv/lib/python2.7/site-packages.
2020-01-01 01:04:19,927 - octoprint.plugin - ERROR - Error while calling plugin softwareupdate
File "/home/stealth95l/OctoPrint/venv/local/lib/python2.7/site-packages/octoprint/plugin/__init__.py", line 219, in call_plugin
File "/home/stealth95l/OctoPrint/venv/lib/python2.7/site-packages/octoprint/plugins/softwareupdate/__init__.py", line 109, in on_after_startup
self._check_environment()
File "/home/stealth95l/OctoPrint/venv/lib/python2.7/site-packages/octoprint/plugins/softwareupdate/__init__.py", line 196, in _check_environment
and get_comparable_version(versions["pip"]) >= get_comparable_version(MINIMUM_PIP)
File "/home/stealth95l/OctoPrint/venv/local/lib/python2.7/site-packages/octoprint/util/version.py", line 148, in get_comparable_version
if "-" in version_string:
TypeError: argument of type 'NoneType' is not iterable
OctoPrint 1.3.12, not on a Pi so I assume no Octopi version, Printer is a Ender 3 Pro, don't have access to my printer firmware atm, Browsers Firefox/Chrome, Operations System Ubuntu 18.04.3 LTS Bionic and I do have this running in a Virtualbox. Any help would be greatly appreciated! Also can I convert slice lts files using octopi or do I need to use a external slicer like Cura? Thanks again for all the hard work you guys do!
