Octoprint ontop of Raspbian
OctoPrint WARNING - Plugin "OctoPi Support Plugin" did not pass check
Not sure what to try to solve this
this is the command I ran " ~/OctoPrint/venv/bin/octoprint serve
(per https://github.com/foosel/OctoPrint/wiki/Setup-on-a-Raspberry-Pi-running-Raspbian)
here is what I got, not sure what this all means or where I should go from here.
pi@raspberrypi:~/OctoPrint $ ~/OctoPrint/venv/bin/octoprint serve
2018-03-24 15:05:10,329 - octoprint.startup - INFO - ******************************************************************************
2018-03-24 15:05:10,330 - octoprint.startup - INFO - Starting OctoPrint 1.3.6
2018-03-24 15:05:10,331 - octoprint.startup - INFO - ******************************************************************************
2018-03-24 15:05:10,406 - octoprint.plugin.core - INFO - Loading plugins from /home/pi/OctoPrint/venv/lib/python2.7/site-packages/OctoPrint-1.3.6-py2.7.egg/octoprint/plugins, /home/pi/.octoprint/plugins and installed plugin packages...
2018-03-24 15:05:11,408 - octoprint.plugin.core - WARNING - Plugin "OctoPi Support Plugin" did not pass check
2018-03-24 15:05:12,161 - octoprint.plugins.discovery - INFO - pybonjour is not installed, Zeroconf Discovery won't be available
2018-03-24 15:05:12,169 - octoprint.plugin.core - INFO - Found 7 plugin(s) providing 7 mixin implementations, 4 hook handlers
2018-03-24 15:05:12,306 - octoprint.server - INFO - Intermediary server started
2018-03-24 15:05:12,307 - octoprint.plugin.core - INFO - Loading plugins from /home/pi/OctoPrint/venv/lib/python2.7/site-packages/OctoPrint-1.3.6-py2.7.egg/octoprint/plugins, /home/pi/.octoprint/plugins and installed plugin packages...
2018-03-24 15:05:12,314 - octoprint.plugin.core - WARNING - Plugin "OctoPi Support Plugin" did not pass check
2018-03-24 15:05:12,877 - octoprint.plugin.core - INFO - Found 7 plugin(s) providing 7 mixin implementations, 4 hook handlers
2018-03-24 15:05:12,919 - octoprint.filemanager.storage - INFO - Initializing the file metadata for /home/pi/.octoprint/uploads...
2018-03-24 15:05:12,921 - octoprint.filemanager.storage - INFO - ... file metadata for /home/pi/.octoprint/uploads initialized successfully.
2018-03-24 15:05:12,954 - octoprint.plugins.softwareupdate - INFO - Loaded version cache from disk
2018-03-24 15:05:15,143 - octoprint.util.pip - INFO - Using "/home/pi/OctoPrint/venv/bin/python -m pip" as command to invoke pip
2018-03-24 15:05:17,352 - octoprint.util.pip - INFO - Version of pip is 9.0.3
2018-03-24 15:05:17,355 - octoprint.plugin.core - INFO - Initialized 7 plugin implementation(s)
2018-03-24 15:05:17,363 - octoprint.plugin.core - INFO - 7 plugin(s) registered with the system:
|  Announcement Plugin (bundled) = /home/pi/OctoPrint/venv/lib/python2.7/site-packages/OctoPrint-1.3.6-py2.7.egg/octoprint/plugins/announcements
|  Core Wizard (bundled) = /home/pi/OctoPrint/venv/lib/python2.7/site-packages/OctoPrint-1.3.6-py2.7.egg/octoprint/plugins/corewizard
|  CuraEngine (<= 15.04) (bundled) = /home/pi/OctoPrint/venv/lib/python2.7/site-packages/OctoPrint-1.3.6-py2.7.egg/octoprint/plugins/cura
|  Discovery (bundled) = /home/pi/OctoPrint/venv/lib/python2.7/site-packages/OctoPrint-1.3.6-py2.7.egg/octoprint/plugins/discovery
|  Plugin Manager (bundled) = /home/pi/OctoPrint/venv/lib/python2.7/site-packages/OctoPrint-1.3.6-py2.7.egg/octoprint/plugins/pluginmanager
|  Software Update (bundled) = /home/pi/OctoPrint/venv/lib/python2.7/site-packages/OctoPrint-1.3.6-py2.7.egg/octoprint/plugins/softwareupdate
|  Virtual Printer (bundled) = /home/pi/OctoPrint/venv/lib/python2.7/site-packages/OctoPrint-1.3.6-py2.7.egg/octoprint/plugins/virtual_printer
2018-03-24 15:05:19,393 - octoprint.environment - INFO - Detected environment is Python 2.7.13 under Linux (linux2). Details:
|  hardware:
|    cores: 4
|    freq: 1200.0
|    ram: 972369920
|  os:
|    platform: linux2
|  python:
|    pip: 9.0.3
|    version: 2.7.13
|    virtualenv: /home/pi/OctoPrint/venv
2018-03-24 15:05:19,400 - octoprint.server - INFO - Reset webasset folder /home/pi/.octoprint/generated/webassets...
2018-03-24 15:05:19,402 - octoprint.server - INFO - Reset webasset folder /home/pi/.octoprint/generated/.webassets-cache...
2018-03-24 15:05:19,573 - octoprint.server - INFO - Shutting down intermediary server...
2018-03-24 15:05:19,883 - octoprint.server - INFO - Intermediary server shut down
2018-03-24 15:05:19,884 - octoprint.events - INFO - Processing startup event, this is our first event
2018-03-24 15:05:19,886 - octoprint.events - INFO - Adding 0 events to queue that were held back before startup event
2018-03-24 15:05:19,886 - octoprint.filemanager - INFO - Adding backlog items from all storage types to analysis queue...
2018-03-24 15:05:19,891 - octoprint.filemanager - INFO - Added 0 items from storage type "local" to analysis queue
2018-03-24 15:05:19,903 - octoprint.plugins.cura - INFO - Path to CuraEngine has not been configured or does not exist (currently set to None), Cura will not be selectable for slicing
2018-03-24 15:05:19,911 - octoprint.plugins.discovery - INFO - Registered OctoPrint instance on raspberrypi for SSDP
2018-03-24 15:05:19,912 - octoprint.server - INFO - Listening on http://0.0.0.0:5000
2018-03-24 15:05:19,975 - octoprint.plugins.pluginmanager - INFO - Loaded plugin repository data from disk, was still valid
2018-03-24 15:05:20,387 - octoprint.plugins.pluginmanager - INFO - Loaded notice data from disk, was still valid
Additionally I was wondering:
Can I setup an icon on the Raspbian desktop that will run Octoprint or do I have to type the command in a terminal window.
Always fix first problem first:
It didn't find pybonjour, so install it and give it another try.
An Icon would make no sense, OctoPrint is not a desktop application, it has no GUI. here it is explained how to setup the system so that it starts OctoPrint on every boot.
You might want to include the command to reinstall pybonjour. I would, but I don't know it.
Specifically, go to this point in that write-up for information on automatic start up of OctoPrint
You don't need to solve this (and you also can't really). You are not running on OctoPi, so this plugin refuses to load. Completely expected behaviour.
Normally I let the people ask first how to do it, but I will make an exception.
I am not sure how the package is named on Raspbian, but I expect it is the same like in Ubuntu:
sudo apt-get update
sudo apt-get install python-zeroconf
At least that lets the message disappear.
Octoprint is a python script...running in shell
You have to connect to it thru a http website
It should autorun
Did you create a user named pi and put the octoprint software in that directory
