Running two Pi4 Octoprint/Octodash servers for my Prusa and Ender. On one I have a generic 4" HDMI display and on the other a Hyperpixel. I set up the Hyperpixel tonight and followed the instructions to install the drivers and rotate the display. The rotate works fine until you restart the Pi. I have searched for this and it seems to be a Pi issue but I am wondering if anyone here runs the same setup and has encountered this problem. I am not a SSH expert by any stretch but can with instructions make file edits and run setups. Any help is appreciated.
google the issue and found many similar problems with settings not sticking but not this one
NA
Complete Logs
How do you rotate the display? (command/config)
From the Hyperpixel github page"
https://github.com/pimoroni/hyperpixel4
When using ssh --- "DISPLAY=:0.0 hyperpixel4-rotate left". It works and here is the result.
pi@octopi : ~ $ DISPLAY=:0.0 hyperpixel4-rotate left
Rotating display
[sudo] password for pi:
File "", line 3, in
ImportError: No module named screenlayout
Setting matrix: 0 -1 1 1 0 0
/usr/bin/hyperpixel4-rotate: line 10: xinput: command not found
Saving touch settings to /etc/udev/rules.d/98-hyperpixel4-calibration.rules
pi@octopi : ~ $
did you try the /boot/config.txt config?
To rotate your HyperPixel4 you must edit /boot/config.txt and change the following lines:
Change dtoverlay=hyperpixel4 to dtoverlay=hyperpixel4:rotate
Change display_rotate=3 to display_rotate=1
This will rotate both the display and the touchscreen input to match.
If you're using a non-touchscreen HyperPixel4 you need only change display_rotate.
Thanks. I found a Chris's basement video and ended up doing the following which worked. Its odd that when select a print from the Octoscreen display ( i am trying it vs Ocdash) it kicks the graphics to the right.
[pi4]
Enable DRM VC4 V3D driver on top of the dispmanx display stack
#dtoverlay=vc4-fkms-v3d
max_framebuffers=2
display_lcd_rotate=3
