Hi, I've been trying to do the octoprint,but I am having quite an issue with it.
My problem is that whenever I try to boot up the raspberry pi 3 with the octoprint on an SD card in it, it does nothing, but if i insert a different SD card with a different thing on it boots up.
Could you help me?
Oh and could you send picks of the code?
Thanks.
Did you follow theinstructions here, especially the part about imaging it using something like Etcher and updating the octopi-wpa-supplicant.txt file?
99% of bootup problems can be found by connecting a keyboard and monitor.
Not sure what that means.
Yep here are the pics of the SD card, files inside and the wpa-supplcant
Assuming the above pictures are from your not booting configuration, so there is at least one error:
