I have uninstalled all plugins after the first crash but it happened again here are the last 100 lines (to many characters for 200 and the log entrys are redundant)
2019-12-15 19:00:10,296 - octoprint.printer.standard - ERROR - Exception while adding communication log entry to callback <octoprint.server.util.sockjs.PrinterStateConnection object at 0x69ab93f0> connected to ::ffff:192.168.178.126
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/printer/standard.py", line 189, in _sendAddLogCallbacks
callback.on_printer_add_log(data)
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/server/util/sockjs.py", line 297, in on_printer_add_log
self._logBacklog.append(data)
MemoryError
2019-12-15 19:00:13,251 - octoprint.util.comm - INFO - Communication timeout while printing, trying to trigger response from printer.
2019-12-15 19:00:14,490 - octoprint.printer.standard - ERROR - Exception while adding communication log entry to callback <octoprint.server.util.sockjs.PrinterStateConnection object at 0x69ab93f0> connected to ::ffff:192.168.178.126
MemoryError
2019-12-15 19:00:15,710 - octoprint.printer.standard - ERROR - Exception while adding communication log entry to callback <octoprint.server.util.sockjs.PrinterStateConnection object at 0x69ab93f0> connected to ::ffff:192.168.178.126
MemoryError
2019-12-15 19:00:17,324 - octoprint.printer.standard - ERROR - Exception while adding communication log entry to callback <octoprint.server.util.sockjs.PrinterStateConnection object at 0x69ab93f0> connected to ::ffff:192.168.178.126
MemoryError
2019-12-15 19:00:19,483 - octoprint.util.comm - INFO - Communication timeout while printing, trying to trigger response from printer.
2019-12-15 19:00:20,655 - octoprint.printer.standard - ERROR - Exception while adding communication log entry to callback <octoprint.server.util.sockjs.PrinterStateConnection object at 0x69ab93f0> connected to ::ffff:192.168.178.126
MemoryError
2019-12-15 19:00:21,873 - octoprint.printer.standard - ERROR - Exception while adding communication log entry to callback <octoprint.server.util.sockjs.PrinterStateConnection object at 0x69ab93f0> connected to ::ffff:192.168.178.126
MemoryError
2019-12-15 19:00:22,504 - octoprint.printer.standard - ERROR - Exception while adding communication log entry to callback <octoprint.server.util.sockjs.PrinterStateConnection object at 0x69ab93f0> connected to ::ffff:192.168.178.126
MemoryError
2019-12-15 19:00:23,308 - octoprint.printer.standard - ERROR - Exception while adding communication log entry to callback <octoprint.server.util.sockjs.PrinterStateConnection object at 0x69ab93f0> connected to ::ffff:192.168.178.126
MemoryError
2019-12-15 19:00:24,560 - octoprint.printer.standard - ERROR - Exception while adding communication log entry to callback <octoprint.server.util.sockjs.PrinterStateConnection object at 0x69ab93f0> connected to ::ffff:192.168.178.126
MemoryError
2019-12-15 19:00:26,627 - octoprint.util.comm - INFO - Communication timeout while printing, trying to trigger response from printer.
2019-12-15 19:00:27,104 - octoprint.printer.standard - ERROR - Exception while adding communication log entry to callback <octoprint.server.util.sockjs.PrinterStateConnection object at 0x69ab93f0> connected to ::ffff:192.168.178.126
MemoryError
2019-12-15 19:00:27,645 - octoprint.printer.standard - ERROR - Exception while adding communication log entry to callback <octoprint.server.util.sockjs.PrinterStateConnection object at 0x69ab93f0> connected to ::ffff:192.168.178.126
MemoryError
2019-12-15 19:00:28,600 - octoprint.printer.standard - ERROR - Exception while adding communication log entry to callback <octoprint.server.util.sockjs.PrinterStateConnection object at 0x69ab93f0> connected to ::ffff:192.168.178.126
MemoryError
2019-12-15 19:00:29,707 - octoprint.printer.standard - ERROR - Exception while adding communication log entry to callback <octoprint.server.util.sockjs.PrinterStateConnection object at 0x69ab93f0> connected to ::ffff:192.168.178.126
MemoryError
2019-12-15 19:00:30,830 - octoprint.printer.standard - ERROR - Exception while adding communication log entry to callback <octoprint.server.util.sockjs.PrinterStateConnection object at 0x69ab93f0> connected to ::ffff:192.168.178.126
MemoryError
In the syslog in line 115 the kernel seems to kill the octoprint process, in the octoprint log file the last about 40000 lines are the same exception as seen in the pastel code above
