Hi, I am a beginner and new to Octoprint. I have a FlashForge Creator Pro. I installed Octoprint and Manually I can send commands to the printer and the webcam works properly. Now, When I upload and print a x3g file (generated by FlashPrint), Octoprint processes it very fast (few seconds) but nothing happens: No print. Has anyone had the same issue and know how to solve it?
Complete Logs
If I recall correctly (it has been a while) with the GPX plugin you give it gcode (not x3g) and it coverts on the fly. Does flashprint give you the option of outputting gcode?
Hello, I actually followed the instructions reported in the link, step by step. Actually I wrote an email to FlashForge team for support and they replied that FFCP cannot work with octoprint, the USB does not accept anything else than reset of motherboard through FlashPrint and the only way to print is via SD card
That sounds like the "party line" answer. FlashForge printers speak x3g. They do not natively speak GCode.
FlashPrint slices .stl files into x3g. It does not normally output GCode (see @paukstelis response for a possible exception/solution)
OctoPrint is designed around sending GCode to a 3D printer. It does not natively speak x3g. However, Dr. Henry Thomas has developed an OctoPrint plugin that converts GCode into x3g "on-the-fly" so that it can be send to a FlashForge printer connected via USB (which, according to FlashForge, is unsupported).
If you want to use FlashPrint as your slicer, then you have to use an SD card to store the x3g output and sneaker net that SD card to your printer.
If you would like to use OctoPrint and the GPX plugin, then you will need to select a slicer that outputs GCode like Ultimaker Cura, PrusaSlicer, or one of many other options available.
There doesn't appear to be an x3g to GCode converter so that option isn't available.
Thanks for that. What I still do not understand is how Octoprint can send flow of data (with GPX which convert gcode in x3d on the fly) to usb port if this is not able to receive data other than for a reset of motherboard (as FF team states) through flashprint.
Just wanted to tell you that you were just ... right! At the end I learned the basics of Cura and it works! Still some small issues (maybe because of the not perfect configuration) but it works! Thanks!
