Octoprint disconnects randomly during a print with no ryhme or reason
tried 2 different usb cables
Heres the seemingly relivant log info
2018-08-19 08:12:46,857 - octoprint.util.comm - ERROR - Unexpected error while reading from serial port
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/util/comm.py", line 2581, in _readline
ret = self._serial.readline()
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/util/comm.py", line 4615, in readline
c = self.read(1)
File "/home/pi/oprint/local/lib/python2.7/site-packages/serial/serialposix.py", line 501, in read
'device reports readiness to read but returned no data '
SerialException: device reports readiness to read but returned no data (device disconnected or multiple access on port?)
2018-08-19 08:12:46,903 - octoprint.util.comm - ERROR - Please see https://faq.octoprint.org/serialerror for possible reasons of this.
2018-08-19 08:12:46,929 - octoprint.util.comm - INFO - Changing monitoring state from "Printing" to "Offline (Error: SerialException: 'device reports readiness to read but returned no data (device disconnected or multiple access on port?)' @ comm.py:_readline:2581)"
2018-08-19 08:12:46,950 - octoprint.filemanager.analysis - INFO - Starting analysis of local:body.gcode
2018-08-19 08:12:46,955 - octoprint.filemanager.analysis - INFO - Invoking analysis command: /home/pi/oprint/bin/python2 -m octoprint analysis gcode --speed-x=6000 --speed-y=6000 --max-t=10 --throttle=0.0 --throttle-lines=100 /home/pi/.octoprint/uploads/body.gcode
2018-08-19 08:12:47,124 - octoprint.plugins.filamentmanager - INFO - Filament used: 1872.3704 mm (tool0)
2018-08-19 08:12:47,324 - octoprint.plugins.astroprint - ERROR - HTTPSConnectionPool(host='api.astroprint.com', port=443): Max retries exceeded with url: /v2/token (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x6f1cabd0>: Failed to establish a new connection: [Errno -3] Temporary failure in name resolution',))
2018-08-19 08:12:47,407 - octoprint.plugins.astroprint - ERROR - Failed to send print_job request: HTTPSConnectionPool(host='api.astroprint.com', port=443): Max retries exceeded with url: /v2/print-jobs/4b521922767d4b5fab251dece4b734d1 (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x6f330bd0>: Failed to establish a new connection: [Errno -3] Temporary failure in name resolution',))
2018-08-19 08:19:20,118 - octoprint.filemanager.analysis - INFO - Analysis of entry local:body.gcode finished, needed 393.17s
