Chris Riley again shared another well made guide:
Octoprint Raspberry Pi Touch Screen Install - Touch UI - Chris's Basement
Not bad.
- File expansion not necessary
- Windows has difficulty using the hostname if you haven't added Bonjour
- If you run the vendor's install scripts using
sudoit shouldn't be necessary tochmodthe file attributes, you'd think - If this works, then it won't need to add the Desktop install step... Oh wait, no, it installs the PIXEL/Desktop.
- Interesting information at 12:00 minutes into it regarding the need to indicate the network in the
config.yaml->accessControlsection. We should remember this one. I really don't like how he edited hisconfig.yaml(leaving "salt" at the wrong indent level like that for so long).
- The
rebootcommand doesn't need "now" as an argument; he's confused that withshutdown.
I like the particular display he's purchased since it has the orientation-adjustment button.
I'm new to the forum but I've been using (and writing about) OctoPrint for several years. I just published my own OctoPrint touchscreen video yesterday—would love for you guys to check it out and give me feedback. I don't think I have permission to create new topics in the Guides section yet, so hopefully this comment is okay.
Please let me know what you think. Thanks!
I actually created an issue on Adafruit's TFT script installer which talks about the incorrect console-based orientation for the touchscreen. It's an easy fix in the /boot/config.txt file.
Ah yes, I indeed found and attempted to use your fix when I spent a few hours troubleshooting one day.
Not sure if it's a difference in Raspbian version or what, but it didn't work for me.
I checked my Raspbian logs and it said the touch-swapxy, touch-invy, etc. parameters were unrecognized and thus ignored. It even tried splitting the dtoverlay into multiple lines in case it was a character length issue (which I've read about regarding /boot/config.txt), and nothing would get it to recognize those.
I was really hoping to include such a simple fix in the video/guide instead.
Bummer. Perhaps it's a difference in the overlay code itself, noting that I was using the 2.8" there.
Ah that's very possible!
